other than possible vignetting, is there a chance for physical damage? if possible, any sample pics with this combo? I still have my sigma30 from my 1.6crop days and just picked up a 1d4. Thanks.
40dbaby Senior Member 516 posts Likes: 1 Joined Jul 2009 Location: socal More info | Nov 15, 2010 12:59 | #1 other than possible vignetting, is there a chance for physical damage? if possible, any sample pics with this combo? I still have my sigma30 from my 1.6crop days and just picked up a 1d4. Thanks. Only an untrained eye can appreciate the sharpness of a lens...
Nov 15, 2010 13:04 | #2 The vignetting took up half the frame on my 5D2 when I tried it. It was unusable.
jt354 Senior Member 401 posts Joined Oct 2010 Location: Michigan More info | Nov 15, 2010 14:33 | #3 I imagine it'd be fairly bad even on 1.3x, since it vignettes noticeably on crop. It may be all right at f/4 or smaller. You'd definitely have to crop the corners at wide apertures. Zenfolio
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Nov 15, 2010 14:42 | #4 No, the sigma lenses do not poke into the mirror box like Canon EF-S lenses, do, so they are safe to use. Give it a try and see if you consider the vignetting acceptable or not. Taylor
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | bobbyz (?) uses a Sigma 30 on his APS-H body. I seem to remember it being fairly usable.
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | Nov 15, 2010 14:49 | #6 James Weaver wrote in post #11289003 since it vignettes noticeably on crop. I don't notice any vignetting with my Sigma.
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Nov 15, 2010 14:52 | #7 It about -1EV at the edges at f1.4. Normally you wouldn't notice with the typical f1.4 subject and it can even assist in isolation. Taylor
Nov 15, 2010 14:58 | #8 James Weaver wrote in post #11289003 since it vignettes noticeably on crop. I used a Sigma 30 on a 50D, and didn't notice any vignetting... It did however vignette on my 1D Mk II, so I sold it... Mike
Daedalus34r Senior Member 477 posts Joined May 2010 More info | Nov 15, 2010 14:59 | #9 it will mount, but sensor coverage will be inadequate, heavy cropping will be required. BODY :: EOS 7D, EOS 50D
Nov 15, 2010 19:52 | #10 |
pyrojim Goldmember 1,882 posts Likes: 4 Joined Jan 2010 Location: San Jose, CA More info | Nov 15, 2010 19:55 | #11 Are you going to get it still? PhaseOne H25
sonnyc Cream of the Crop 5,175 posts Likes: 36 Joined Jun 2005 Location: san jose More info | Nov 15, 2010 20:01 | #12 egordon99 wrote in post #11289130 bobbyz (?) uses a Sigma 30 on his APS-H body. I seem to remember it being fairly usable. yes Bobby uses his on the 1DMKII. A bit vignetting but stopping down a bit will work fine.
Nov 15, 2010 20:02 | #13 |
| Latest registered member is MWCarlsson 1065 guests, 177 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
