Here is a shot i took today during sunset. The first one is a 3 image HDR and the second one is a non HDR version.
I'm not a real big fan of HDR, but in this case, i'm not very sure which one is better.
C&C appreciated.
wouter88 Senior Member 337 posts Likes: 2 Joined Sep 2008 Location: the Netherlands More info | Nov 15, 2010 15:45 | #1 Here is a shot i took today during sunset. The first one is a 3 image HDR and the second one is a non HDR version. www.flickr.com/woutervandenheuvel
ChuckingFluff Goldmember 1,391 posts Likes: 2 Joined Aug 2010 Location: Canada Eh! More info | Nov 15, 2010 16:21 | #2 What did you use to put the HDR together? It doesn't look like an HDR because theres no real detail in the shadows. Can you post your 3 images?
wouter88 THREAD STARTER Senior Member 337 posts Likes: 2 Joined Sep 2008 Location: the Netherlands More info | Nov 15, 2010 16:30 | #3 ChuckingFluff wrote in post #11289704 What did you use to put the HDR together? It doesn't look like an HDR because theres no real detail in the shadows. Can you post your 3 images? I used photomatix. Well like i said i'm not a real big fan of it so i try to make the HDR photograph very subtle, but squeeze a little bit more color and detail out of it, perhaps too little i suppose? www.flickr.com/woutervandenheuvel
ChuckingFluff Goldmember 1,391 posts Likes: 2 Joined Aug 2010 Location: Canada Eh! More info | Nov 15, 2010 16:35 | #5 If I get a chance later I wouldn't mind playing around with these if it's ok with you? I'm no expert but I like a challenge.
ChuckingFluff Goldmember 1,391 posts Likes: 2 Joined Aug 2010 Location: Canada Eh! More info | Nov 15, 2010 19:12 | #6 File was a little small to work with but I tried to pull a little more detail out of it.
digijune Junior Member 27 posts Joined Jun 2010 Location: New Jersey More info | Nov 17, 2010 22:54 | #7 I like the subject of the photo --- and I also like what Chucking did with it... I need to learn HDR, it's a great effect...
PurplePuppy Senior Member 284 posts Joined Mar 2010 Location: Vancouver More info | Nov 18, 2010 03:37 | #8 I prefer the original non-HDR version. The original HDR version has an unnaturally dim sun (not to be confused with dimsum) and is rather dark in general. Canon EOS Rebel XS | Tamron 17-50mm f/2.8 VC | Tair 11a (135mm f/2.8, M42, manual) | Cheapo aluminum tripod from dealextreme.
Sensei125 Member 116 posts Joined Dec 2005 Location: Currently living and working in Afghanistan More info | Nov 18, 2010 03:42 | #9 I like the non-HDR image personally. The colors have more pop and the image looks more "alive" and the details are sharper to me vs. the HDR image. Chris
PurplePuppy Senior Member 284 posts Joined Mar 2010 Location: Vancouver More info | Nov 18, 2010 03:44 | #10 Sensei125 wrote in post #11305201 Thanks to the filters here in Afghanistan that the Army loves to use I am not able to see what Chuck posted for his HDR creation. Wish I could. What?! the army blocks Flickr? Outrageous! Anyway, you could always use a proxy (unless those are all blocked too) Canon EOS Rebel XS | Tamron 17-50mm f/2.8 VC | Tair 11a (135mm f/2.8, M42, manual) | Cheapo aluminum tripod from dealextreme.
wouter88 THREAD STARTER Senior Member 337 posts Likes: 2 Joined Sep 2008 Location: the Netherlands More info | Nov 18, 2010 09:29 | #11 Thanks for all the feedback and suggestions, i really appreciate it. www.flickr.com/woutervandenheuvel
ChuckingFluff Goldmember 1,391 posts Likes: 2 Joined Aug 2010 Location: Canada Eh! More info | Nov 18, 2010 11:39 | #12 I think theres a lot more detail in there if you shot in raw format. It's kind of hard to get a real good edit with small files and I think some people were looking for a wall mountable print with small files but it's up to you and what you like to look at hdr or not. I think when I was looking at this in photomatix it was -4, 0, +2 EV it's good to keep it consistent as a -2, 0, +2 EV, the overly bright exposure will give you some haloing and brighten some areas more than what is needed. Even with hdr try and stay away from really blown images. Play around with it and have fun with it there a winning shot in there some where.
wouter88 THREAD STARTER Senior Member 337 posts Likes: 2 Joined Sep 2008 Location: the Netherlands More info | Nov 18, 2010 17:36 | #13 ChuckingFluff wrote in post #11306867 I think theres a lot more detail in there if you shot in raw format. It's kind of hard to get a real good edit with small files and I think some people were looking for a wall mountable print with small files but it's up to you and what you like to look at hdr or not. I think when I was looking at this in photomatix it was -4, 0, +2 EV it's good to keep it consistent as a -2, 0, +2 EV, the overly bright exposure will give you some haloing and brighten some areas more than what is needed. Even with hdr try and stay away from really blown images. Play around with it and have fun with it there a winning shot in there some where. Thanks for your feedback. I have been shooting in raw since i started photographing, I just don't post high resolution shots on the web. The shots were -2, 0 and + 2 EV. Well i certainly will keep experimenting and hopefully get the result i'm looking for. www.flickr.com/woutervandenheuvel
Drakeskakes Goldmember 1,487 posts Likes: 1 Joined Nov 2009 Location: San Diego More info | Nov 18, 2010 17:40 | #14 I would use the brush tool on LR3 and run it through the sky with Contrast-Clarity-Sharpenn turned up. It'll bring out a more dramatic scene "Nobodys built like you....
GorgeShooter Goldmember 1,422 posts Joined Mar 2009 Location: Oregon More info | Nov 18, 2010 17:42 | #15 Non-HDR hands down 1DX | 5D MkII (gripped)
| Latest registered member was a spammer, and banned as such! 2530 guests, 157 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
