Just thought I would share my bad experience with Apple computers.
First let me say I was always a long time supporter of Apple owning several machines and always recommending apple computers but this has me rethinking my position.
About 7 months ago I purchased a macbook pro loaded with everything ( 1 of my 4 machines I use by Apple, 2 at work and 2 at home but older ) with a Cinema display with apple care for a total of around $4000. The macbook pro was an I7 quad core with 8 gigs of ram upgraded Hard drive and display. From the moment I started using it I noticed it was not performing very well so I called apple and they had me check somethings and claimed it was fine. I pretty much kept it on the charger most of the time but when I did take it off the charger the battery only lasted about 2 hours ( much less then the 8 - 10 they advertise ) After countless calls to tech support telling me to check various things and run disk utilities as well as a few trips to the apple store to replace the battery and test it the machine began doing whats called kernel panics where it simply turns grey and it must be restarted ( I loose everything I have been working on since its a full crash )
Again countless calls to tech support having me do various tests before finally erasing the hard drive and starting over with a full reinstall. Still same problem, about 2 days after cleaning it out and reinstalling the system software I am still having the same trouble so I finally asked apple to replace or refund me for the machine since it has never worked. Apple has flat out refused to do anything but repair the machine but I feel a repair of something that has never worked properly is not fair. They claim that its to far past the date of purchase for a replacement even though I have had so many issues with the machine that I cannot even use it for work.
Now I understand they cannot replace ever computer that has a minor issue but my issues make the machine useless. I was hoping that something can be done since the "higher up" person I spoke with told me they will not replace it since I need 3 or 4 hardware failures to possibly get a replacement and even then they are not certain. I don't feel comfortable with a machine this expensive that has to be repaired so many times that has hardly even been used.
They did agree to take it in and look at it but that does not seem right to me. In the past Apple offered great support but I feel things have changed with how this matter was handled so I am stuck sending in my machine for about 2 weeks while they look at it and let me know.
Does this seem right?
