Thread started 17 Nov 2010 (Wednesday) 07:06
TAMRON 17-50MM F2.8 XR DI II VC on mkIII?
Tyreman
Nov 17, 2010 07:06 |  #1
will the Tamron 17-50 f/2.8 xr di II vc lens work okay on a mark III?
Thanks in Advance
Cambridge, ON.
watt100
Nov 17, 2010 09:20 |  #2
Tyreman wrote in post #11299624 (external link)
Thanks in Advance
no, do a search - Tamron 17-50 is for 1.6 crops!
SkipD
Joined Dec 2002
Nov 17, 2010 09:34 |  #3
Thanks in Advance
The lens would mount on the camera OK, but there would be noticeable vignetting (dark circle around the image) because the lens is designed for APS-C format cameras and not the APS-H or the so-called "full-frame" cameras.
Skip Douglas
daclozer
Nov 17, 2010 22:43 |  #4
Tyreman, I really want you to have that lens so I will trade you my 30D for your camera so you can use that lens..... Just kidding...
2 30D/BG-E2
70-200L f2.8 Canon
28-75mm f2.8 Tamron
www.freezeframefoto.bi​z (external link)
http://www.etsy.com/sh​op/freezeframefoto (external link)
Replaces
Nov 17, 2010 22:58 |  #5
lens is designed with the crop factor of 1.55 (not exactly 1.5 or 1.6 b/c it has to fit both nikon and canon =D).
It probably will be ok with some range but not so with others.
asamimasa
Nov 18, 2010 02:12 |  #6
You'll get solid black vignetting (the kind that you can't correct in PP).
Zoomed all the way in you might be able to get away with it, but there must be a lot better options than a 50mm 2.8 IS.
Gear List here
2,268 views & 0 likes for this thread, 6 members have posted to it.
1032 guests, 109 members online
