Thread started 17 Nov 2010 (Wednesday) 17:55
Is my new Imac going to be powerful enough for Canon's h.264?
timeflight
Joined Nov 2010
Nov 17, 2010 17:55 |  #1
I have bought an Imac with an Intel Core i5 760 (quad) processor and 4 GB memory. (The most expensive stock Imac)
We also have Final Cut Pro's latest version, including the compressor.
I have read that the footage (movie) from Canon's 7D, 55D/t2i and 60D (which I will buy) is compressed to the h.264 format, which is very heavy for your computer.
So, will this Mac play the footage easily? Can I edit it after I compressed it to Apple's ProRes?
Or is this simply not powerful enough?
Tony-S
Nov 17, 2010 18:28 |  #2
If you just want to play it, it'll be great with Quicktime. QT under 10.6.3+ has h.264 acceleration on the gpu. Final Cut should be fine too. Just remember you have to render h.264 video before you can edit it because it is frame-compressed.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
Telemov
Nov 17, 2010 18:43 as a reply to  @ Tony-S's post |  #3
All the Mac users I know convert to ProRes for editing. Not sure about previewing.
I have a dual core PC 2.13 ghz with 4gb RAM. It can't play raw h.264 well, but once converted with NeoScene I can preview and edit just fine with cs3.
I believe cs5 will handle your h264 files natively if you're willing to join the Adobe camp.
timeflight
Joined Nov 2010
Nov 17, 2010 18:55 |  #4
Telemov wrote in post #11303148 (external link)
Well we bought an Imac, mainly so we could work with Final Cut Pro and 1 reason being the ProRes compressor. PC's are much cheaper so I cant skip to Premiere now :p I would feel like I threw money away:P
Anyway, if your dual core with lower MHZ could edit just fine after it has been converted with NeoScene, I guess my i5 quad could do the same after it has been converted to Prores.
But for now, I hope that someone with a similar setup as mine could tell me that for sure :d
MaxxuM
Nov 17, 2010 22:21 |  #5
timeflight wrote in post #11303202 (external link)
Premiere and FCP are on par with each other these days, though Premiere is two and a half generations ahead so their rendering engine is superior. However, Motion & Color more than make up for this. I do professional video and have started working with 7D files. It's been a learning experience :)
Anyway, you really need to start reading this (link (external link)). It will answer all your questions about the 5DMKII and 7D workflow.
timeflight
Joined Nov 2010
Nov 18, 2010 03:26 |  #6
MaxxuM wrote in post #11304313 (external link)
Thanks. Informative.
But it doesnt answer the question if the Imac I have with the specs will be fast enough for (pleasant) editing.
MaxxuM
Nov 18, 2010 08:03 |  #7
Yes, it is. There you go. :) An i7 would be better, but only around 10% faster, but if you render hour long movies that 10% adds up.
ChasP505
"brain damaged old guy"
Nov 18, 2010 08:20 as a reply to  @ MaxxuM's post |  #8
Good discussion:
http://photo.net/digit​al-darkroom-forum/00XeNq (external link)
Chas P
Telemov
Nov 18, 2010 09:39 as a reply to  @ ChasP505's post |  #9
Just to clarify, CS5 is also available for Mac. I just read a post on another forum by a poster who was gushing about how well his MacBook with CS5 handled native DSLR files, multiple other formats, dropped into the timeline rescaled, and scrubbable/editable with no rendering. Google your MacBook/Premiere CS5 combo and see what others have said.
Example: http://www.cinema5d.co​m ….php?f=29&t=143​26&start=0 (external link)
I'm looking forward to reading the threads posted in the previous posts. I was devastated when I tried importing my brand new 7D video files into my clunky two year old system with CS3 only to find I couldn't edit them without converting first.
I know we all have budgets and comfort zones with our NLE software (Mac+FCP/PC+CS5, for example), so I can totally understand your desire to stick with what you have. CS5 just looks so awesome I have to pimp it. I watched them playback 16 simultaneous video tracks in various formats, all of them rescaled, and nearly cried. Want.
benesotor
Nov 18, 2010 13:07 |  #10
- To play back the files, yes. Most computers can do that (albeit at a reduced resolution).
- Editing is different... without transcoding, then it will be choppy. Transcode the footage to pro-res and you'll be a-ok with the i5.
- CS5 is a bit different, no need to transcode... although I expect FCP to have the ability before long. Having said that, transcoding will always be the best way to go, better to colour-correct with 4:2:2 colour than the h.264.
1,450 views & 0 likes for this thread, 6 members have posted to it.
1261 guests, 122 members online
