What is the effect of picture styles on RAW image files?
TomBrooklyn Member 204 posts Joined Jun 2006 Location: Brooklyn, NY More info | Nov 18, 2010 12:40 | #1 What is the effect of picture styles on RAW image files?
TTk Goldmember 2,518 posts Likes: 4 Joined Oct 2007 Location: Langtoft. England. More info | Nov 18, 2010 12:43 | #2 None..as raw is raw... Terry.
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Nov 18, 2010 13:17 | #3 You will see picture styles applied to RAW files only if you open the RAW files in Canon DPP. You still have the option of changing to other styles or doing custom adjustments. Third party softwares are not set up to use the picture style parameters that are tagged to the RAW file. Alan Myers
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | Picture styles suggest how the photo would look if the camera was set to take JPGs and did its own internal processing. As said already... picture styles have no effect on the raw file. Chas P
Riveredger Senior Member 670 posts Likes: 1 Joined Jul 2010 Location: NJ More info | Nov 18, 2010 14:42 | #5 amfoto1 wrote in post #11307432 You will see picture styles applied to RAW files only if you open the RAW files in Canon DPP. You still have the option of changing to other styles or doing custom adjustments. Third party softwares are not set up to use the picture style parameters that are tagged to the RAW file. Picture styles will also effect what you see on the camera's LCD while shooting RAW. Not that the LCD is all that accurate to begin with. Perfect answer.
mattia Senior Member 528 posts Likes: 2 Joined Feb 2009 More info | Nov 18, 2010 15:17 | #6 You can apply any and all in DPP after the fact, should you want to. 5DII | 300D | 30D IR | 17-40L | 24-105L IS | 70-200/2.8L IS | 100-400L IS | 15 FE | 35L | 50/1.8 mk I | 135L | Sigmalux 50/1.4 | Sigma 105/F2.8 Macro | C/Y Planar 50/1.4 | C/Y Distagon 35/2.8
| Latest registered member is semonsters 1060 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
