Thread started 20 Nov 2010 (Saturday) 05:49
How Import Photos Into DPP With Card Reader?
TomBrooklyn
Nov 20, 2010 05:49 |  #1
How do I import photos into DPP from a Card Reader?
When I upload photos straight from a camera, the EOS Utility opens and I can select "Starts to download images," which does so and opens Zoombrowser Ex for jpgs and DPP for RAWs.
When I put my CF card into a Sandisk card reader, I can't see how to get them to DPP. The EOS Utilities window's selections are greyed out.
NinetyEight
"Banned for life"
Nov 20, 2010 07:09 |  #2
You will need to copy them from the card to a folder on your PC (Where your other raw files are stored would be a good place).
Then simply use the folder/file browser in DPP to view the files.
Kev
René ­ Damkot
Nov 20, 2010 07:40 |  #3
Just drag and drop or copy/paste them using the OS.
Edit: Note to self: refresh before posting.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
PixelMagic
Nov 20, 2010 08:27 |  #4
As already stated you can't import into DPP directly from a card reader. EOS Utiility is designed only to recognize "camera events" i.e. when a camera is plugged into your computer.
You can probably tweak AutoPlay in your Windows Registry to recognize "Card reader events" and invoke EOS Utility but I'm not sure its worth the trouble.
What version of Windows are you using?
TomBrooklyn wrote in post #11316476 (external link)
TomBrooklyn
Nov 20, 2010 09:07 as a reply to  @ PixelMagic's post |  #5
OK, thanks. I'm using Windows XP.
Lowner
"I'm the original idiot"
Nov 20, 2010 12:57 |  #6
This is my big complaint with card readers. Mine creates a file called "Canon100" on the PC hard drive, sticks all the images in it and thats it. I'm left with the task of creating a proper file and transferring all the images across,. renaming as I go (I forgot to say it mucks up the individual file naming as well). It has taken me several hours of careful work to put right.
When Eos Utility uploads direct from camera, it creates a dated file in my external dual drive and when its finished, DPP opens. Perfect. Card readers are not the Godsend some believe them to be.
Richard
tonylong
...winded
Gallery: 60 photos
Nov 20, 2010 14:46 |  #7
ZoomBrowser has the Acquire tool with a Memory Card function. I haven't used it since I use Lightroom to download, but give it a try.
Tony
René ­ Damkot
Nov 20, 2010 15:38 |  #8
Lowner wrote in post #11317593 (external link)
Plenty of software, some free, that does that for you ;)
So, you are comparing downloading from camera, using software (EosUtility) to copy-pasting files from card reader?
Not exactly a 1 to 1 comparison I'd say...
I use ImageIngester and a card reader. Does everything Eos Utility does, and more. :mrgreen:
Lowner
Nov 20, 2010 15:52 |  #9
Rene,
You misunderstand. Eos Utilities is slow when there is a large number of files to upload. The standard response is "Use a card reader". When for some reason my PC died on me mid upload, Canon commiserated but agreed that there was no way on Gods earth I could complete the download because the PC recognised some of the files and refused to redownload anything. The only way was to buy a card reader, which I did. The ensueing nightmare took 2 evenings solid work to put right, just because the card reader did what it was designed to do.
Maybe others prefer it, for the "faster upload",but I most certainly don't. I will never use it willingly again. I say the comparison was a fair one. A choice between leaving my PC to get on with it for an hour while I clean my shoes, have a cup of coffee, whatever or spend several hours clearing up the mess.
Richard
TomBrooklyn
Nov 21, 2010 11:25 as a reply to  @ Lowner's post |  #10
I actually never felt the need for a card reader in my ordinary workflow. I usually download 1 card per session with 300-400 photos on it. It seems to me it might only be really useful for those downloading multiple cards with a thousand or more RAW photos at one time.
I only bought the card reader when I screwed something up one time and wanted to try to recover some lost photos. I needed the reader to replicate a separate hard drive to run the recovery software.
I have not usually liked using the card reader much ever since. It hasn't followed my numbering system sequence for one thing, and it has never seemed to work out easily.
Still, I try it now and them for various reasons.
I didn't know about separate software to use with the reader. I may look into that.
Lowner
Nov 21, 2010 13:49 |  #11
Tom,
Two of us against the world, or thats how it seems. The rest of the world is totally in favour of the things.
Richard
PixelMagic
Nov 21, 2010 14:03 |  #12
I've never seen a card reader create a folder on a hard drive as you describe. What operating system are you using?
sue.t
Gallery: 30 photos
Nov 22, 2010 10:59 |  #13
On my desktop with XP, when I put the CF card in the card reader, a series of options appears with the query, "What do you want to Windows to do?".
On the list is "View/Download Images using CanonZoomBrowser EX".
Selecting that option brings up the little window for ZoomBrowser EX with buttons to choose either "Download Images" or "Lets you select and download images".
The "Lets you select ... " option shows a preview of the RAW files and lets you select which you wish to download, and then you can also rename the files and have them copied to a folder on your hard drive of your choosing.
On the laptop (Windows Vista) I use the EOS Utility because it doesn't have a card reader for CF cards. The laptop is used when we're travelling and I prefer to not carry a separate card reader because the camera & EOS Utility do a fine job. The EOS Utility copies the RAW files across much quicker than ZoomBrowser does. It also provides the option of renaming the files and putting them into a specific location on the hard drive.
Lowner
Nov 22, 2010 12:58 |  #14
Pixel Magic,
"I've never seen a card reader create a folder on a hard drive as you describe. What operating system are you using"?
Plain vanilla flavour Windows XP
Richard
Riveredger
Nov 22, 2010 13:17 |  #15
Lowner wrote in post #11327279 (external link)
Pixel Magic,
It's actually your camera that creates those folders. You just need to double click on it and then "Select All" the actual files and drag them into a folder on your PC.
I have a folder called "RAW" on my desktop. I simply drag everything into that one folder. I have DPP set up to open right to that folder, too. It's really simple.
Flickr Photostream (external link)
18,812 views & 0 likes for this thread, 15 members have posted to it.
1060 guests, 104 members online
