Thread started 20 Nov 2010 (Saturday) 10:17
7D setting for BIF
sagebrush
Joined Dec 2001
Nov 20, 2010 10:17 |  #1
I can't seem to get sharp shots with my 7D for BIF.
What is the best CFn setting, apature, shutter speed, and auto focus setting when shooting BIF?
ichigosa
Nov 20, 2010 10:22 |  #2
in my oppinion, leave cfn settings alone. aperture low, shutter speed high (like 400 or so), al servo focus and very importantly, image stablisation OFF.
http://www.flickr.com/​photos/imaginethesky/ (external link)
www.imaginethesky.com (external link) - my blog
Equipment: Canon EOS 30D, 17 - 85mm USM, 50mm f1.8, 70 - 300 IS USM, 430 EX Speedlight
GyRob
Nov 20, 2010 10:47 |  #3
There are quite a few that can be good but try this, tracking speed slow - lens wide open and at leased twice or three times the focal lenth in shutter speed i.e 300mm 1/1000 sec . single focus point or if a clear sky background pick a point and use expand ,Zone can also be good .
Rob.
"The LensMaster Gimbal"
Garry ­ Gibson
Gallery: 41 photos
Nov 20, 2010 11:06 |  #4
Take a look at this guide by Doug Brown a professional bird photographer.
For sure don't turn off your image stabilization, that's what it's there for there.
On most lens there are two stabilization modes one when you are sitting still
and one when you are tracking.
I saw the other day where a guy bought a new 400 5.6 L and took 1,000 shots
before he felt he got one he was really happy with. It is something that takes
work and trial and error.
Good luck, hope Doug's guide is of some help.
http://www.deepgreenph​otography.com …ing-up-your-new-canon-7d/ (external link)
5D SR- 7D Mark II
Some assorted glass
Learning everyday... well.. maybe every other day.
sagebrush
Joined Dec 2001
Nov 20, 2010 11:26 |  #5
Those are some interesting suggestions. I had the Tracking speed on Fast so I'll try the slow setting.
I had my shutter at only 1x the Focal Length so that could be a major factor.
Any suggestion on setting C.Fn III-2, -3, -4, and -7 ?
The Doug Brown guide looks very good ...I'l try his suggestion too.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Nov 20, 2010 13:27 as a reply to  @ sagebrush's post |  #6
If we assume you are shooting against the blue sky, then you can also experiment with more than one focus point. Sometimes it's difficult to keep one point on the bird. The drawback is of course that a point may focus on the wingtip or something.
Tracking timeout slow is good. Reduces risk of loosing focus.
The other Servo AF custom functions you can leave at default. It takes more complex situations than a bird on the sky to make them useful. Set the range limiter on your lens to the longer distance.
Short shutter speed reduces movement blur, and also neutralizes the effect of IS. Which means it doesn't matter much if you have it on or off.
Anders
omer
Gallery: 80 photos
Nov 20, 2010 14:19 as a reply to  @ apersson850's post |  #7
We do not see any indication on the lens you use - it is as important (more) than a specific c-setup
My Flickr (old) http://www.flickr.com/​photos/omfoto/ (external link)
R6 | 80D | 7D | M6 |RF24-105 STM|RF35 1.8| EF-S 15-85 |EF 70-300 L |Sig 150-600 C| Sig 10-20 | 50 1.8 |100 2.8 macro|28 F2.8 | efs24| efm 15-45| 270EX | 430EXII |
sagebrush
Joined Dec 2001
Nov 20, 2010 17:43 as a reply to  @ omer's post |  #8
I've tried different lens depending on the distance to subject. These birds are woodpeckers and jays and about 100-200 feet away flying from feeder to their favorite tree (across infront of me). I use a 300/f2.8 IS both with and w/o a 1.4x TC. I've also tried using a 500/f4 IS but the image starts to fill the frame too quickly and harder to follow in flight.
sagebrush
Joined Dec 2001
Nov 20, 2010 17:46 as a reply to  @ sagebrush's post |  #9
BTW, the birds are flying with trees in the background .... not sky.
ichigosa
Nov 22, 2010 03:51 |  #10
i find that i get better results with IS turned off. maybe its just me but here's why.. i often follow the bird through the lens and pan with it for the duration of the flight while al servo keeps it in focus. I i keep my other eye open to make sure i dont lose the bird. Although i could set IS to the mode for horizontal panning, the birds dont always fligh straight from left to right. I find that ultimately, the IS tries to resist my panning which just seems to frustrate me. Although if you are composing the shot first and waiting for the bird, it would make no difference other than giving you a nice stable view through the view finder..
GyRob
Nov 22, 2010 06:36 |  #11
sagebrush wrote in post #11318589 (external link)
single point and slow tracking for this conbined with whats called pumping the shutter button .ie you have to be ready to half press the shutter to regain focus should you lose AI servo focus to the background.
Rob.
GrizzlyMan
Nov 22, 2010 07:14 |  #12
Great question.... I have a 7d and wildlife is what I mostly shoot. Lately Eagles in MD.
I have experimented with all sorts of settings and have used many lenses and here is what I have found to work for me after 10k clicks.. I am still trying to figure out the best but my success rate has gone way up.
- As for CF settings... Nothing major
- ai servo for BIF, I have my tracking in the middle. I seem to have less lens search there.
- Full auto focus and at times center spot -- full auto, lock in half shutter and track and shoot but never let your finger off half. Aim for the eye. Center spot same deal but harder too track and hold on subject.
- IS on if you have it..
- Manual exposure -- 1250 shutter speed, f-6.3, auto iso.. I also use AE mode.. all depends on the sky.
There is no trick.. its practice and understanding what the camera is capable of doing. The 7d is pretty smart..
Good luck and practice and look at others images and learn.
Kurt
www.ThruKurtsLens.com (external link) & Flickr (external link) & 500px (external link)
Canon 1dmkIV, 7DII, 5DmkIII ~ 17-40 4.0 L, 70-200 2.8 IS L, 24-70 2.8 L, 500 L 4.0, 1.4x extender, 2x extender, 580 speedlight, Think Tank Backpacks & Bags.......
Chris
Nov 22, 2010 07:31 |  #13
I'm still learning my 7D and mostly on large birds, but I really like the expanded point focus. Very nice write up Doug Brown
Chris
70D | 24-70 2.8 | 400 5.6 | 580 EXII | 2X Yongnuo 622C |
hollis_f
Nov 22, 2010 07:33 |  #14
sagebrush wrote in post #11317243 (external link)
This made the biggest difference in the number of keepers for me. I'm still not very good at tracking BiFs, so having the camera not switch to the background as soon as I lose the bird is a real boon.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
2,940 views & 0 likes for this thread, 9 members have posted to it.
7D setting for BIF
1212 guests, 131 members online
