Recently I haven't had a lot of luck getting answers to LR questions but perhaps someone knows the answer to this one.
I always try to learn as many keyboard shortcuts as possible and I've gotten pretty good.
In LR2 I could enter the crop mode using the R key and then cmd-right arrow (Mac OS) to move to the next image while staying in the crop mode. I could also use the X key to mark the image as rejected without leaving the crop mode.
I found that in LR3 the crop mode works the same but if I use the X key it no longer marks the image as rejected. In crop mode the X key will invert the aspect ratio from vertical to horizontal and vice versa and the only way for me to mark the images as rejected is to leave the crop mode and use the X key.
Is there another or new keyboard shortcut that will allow me to mark an image as rejected while in crop mode without interrupting the workflow?
