Thread started 21 Nov 2010 (Sunday) 18:47
Macro Possibilities
Red ­ Tie ­ Photography
Nov 21, 2010 18:47 |  #1
Here is the situation. Im a wedding photographer, and I feel I need macro capabilities. I wont be using it an incredible amount, just for rings, small details, etc. I have the lenses in my sig.
I pretty much decided on the 100mm 2.8, non-L. I played with the L a little, and while it is nice, I dont know if it is THAT much nicer than the non-L. Then I started looking at tubes after a photographer I shot with last night used a Canon 12mm. I have been looking around a little bit and had a few questions.
What lens would work best with the tubes?
Which is the best extension tube to use? Should I go with the Kenko kit with the three tubes? Or do I only need one?
Canon vs Kenko? I read they are basically the same.
I look forward to the replies, I know this forum has a wealth of knowledge.
Bryan
Gear List (external link)
San Diego Wedding Photography - Red Tie Photography (external link)
Red Tie Photography Blog (external link)
yjt
Joined Nov 2010
Nov 21, 2010 18:49 |  #2
Kenko has nice extension tubes, they come in 3s but you might not need all of them for 1:1
7D (Gripped) || 24-70 f2.8L || 50 f1.4 || 70-200mm f4L
themadman
Nov 21, 2010 18:52 |  #3
1. The 100non-L is pretty much just as good as the L IMO, if you really need the IS or has a body to use the IS for macro (which only the 7D and 1D4 have I think) then you aren't gaining that much.
2. Any prime tends to work well, your 135, 85, and 50 should all perform great
3. I would just go Kenko and get the kit of three. FOr around $140 it gives you flexibility at about the cost one Canon tube.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
Nov 21, 2010 19:02 |  #4
themadman wrote in post #11323430 (external link)
This confirms what I was thinking. I dont have IS on any of my lenses, and have found I havent really NEEDED it.
I was also thinking about my 135 and 50. The 85 doesnt focus as close, but im guessing with the tubes that would change? I dont really understand how the tubes really work to be honest, and how do I combine them to create 1:1 macro?
The set of 3 makes sense, and for a third of the price of a macro lens, and less space, it sounds good.
Bryan
themadman
Nov 21, 2010 19:05 |  #5
Extension tubes will definitely change the 85's ability to focus close.
As for how to get 1:1... it is a bit voodoo to me, but Brian tries to explain it in THIS thread: https://photography-on-the.net/forum/showthre​ad.php?t=807056
Saying this:
Magnification with extension tubes
For a non macro lens with extenson tubes the magnification is given by the formula
magnification = length of ext tubes (mm)/focal length of lens (mm).
So for a 50mm lens with a set of extension tubes totalling 68mm the max magnification = 68/50 = 1.36:1
I wouldn't worry about magnifications much as just getting the shot you want. Even if in the future you get a macro lens, you can still use your extension tubes with it! =)
Nov 22, 2010 00:02 |  #6
Sounds great. Thoes look the way to go.
Bryan
Mookalafalas
Gallery: 54 photos
Nov 22, 2010 00:07 |  #7
I was looking through the 85mm thread the other day and saw some really awesome Macro work done with the Kenko tubes. It made me regret buying my Macro lens (which I love, btw). Apparently it not only works, but works well!
ChasWG
Nov 22, 2010 02:24 |  #8
I'm with Will on this one. Get the Kenko tubes and use your 85mm or 135mm lens.
I have the same 85mm f1.8 and love to put 56mm of ETs behind it, using the manual focus technique of rocking back and forth until the focus reticle lights up.
All images shot using a Canon 40D, Canon EF 85mm f1.8, Kenko Extension Tubes and some macro style off camera lighting.
IMAGE: http://farm5.static.flickr.com/4129/4975334916_253cd77748_b.jpg
IMAGE: http://farm5.static.flickr.com/4095/4913460929_e513ee9ef9_b.jpg
IMAGE: http://farm5.static.flickr.com/4135/4884687240_835d8aa1fc_b.jpg
IMAGE: http://farm5.static.flickr.com/4082/4942740085_64ab109c48_b.jpg
IMAGE: http://farm5.static.flickr.com/4115/4881935836_1ced0d3427_b.jpg
ET's are just too much fun to play with. I also have a EF 24-70 f2.8L that is considered a "macro" lens because it can focus so very close, but if I add a 20mm tube to the back of that one, I'm really in there. It's just that lens hood that gives me and the bugs fits. I have become very comfortable with the 85mm and some tubes. A very nice set up for not a lot of money.
edit: If that is the route you go, you're also going to need to add some suplimental lighting. Once you move in that close your DoF is almost nothing. Adding more, soft light will get you the f-stops need for detail work. Here's a shot done at f11, the distance between the two flowers was not all that great. Maybe .5 inch to .75 inch.
IMAGE: http://farm5.static.flickr.com/4106/4992586716_6538bbcbb9_b.jpg
IMAGE: http://farm5.static.flickr.com/4131/4991978245_3ecb766777_b.jpg
Also @ f11, notice that the upper flower is already starting to fall out of focus. These flowers are teeny tiny, less that .5 inch across if that gives you any idea of the size we are talking here.
Chas Gordon
7D Gripped/40D Gripped/10-24/EF24-70 f2.8L/EF70-200 f4L/EF50 f1.8 Mk I/EF85 f1.8
http://www.flickr.com/​photos/chaswg/ (external link)
http://vimeo.com/user9​461302/videos (external link)
Mookalafalas
Gallery: 54 photos
Nov 22, 2010 02:32 |  #9
Charles, it was your work I was referring to (seen in the Canon 85mm 1.8 thread) above. Terrific stuff!
phreeky
Nov 22, 2010 02:38 |  #10
You should only need about 1:2 by the sounds of things. If there is a lens you own that you don't normally use for weddings you might want to try a tube on that and then leave it fitted to it so you don't have to fumble around at the wedding.
ChasWG
Nov 22, 2010 02:51 |  #11
Mookalafalas wrote in post #11325227 (external link)
Thanks man, your kind words are much appriciated. It took me the better part of this past summer to finally dial in my technique with the 85mm and the macro flash. But it works!
As for using one lens for the macro so you don't have to fumble. Shooting macro stuff is so different from the normal wedding/event style of shooting because of the lighting, you really need to stop down from shooting anything else to focus on doing only the macro stuff. Switching back and forth will be a real pain at first. I built my own macro flash bracket so I could have the stobe already placed when I was chasing the bugs around my backyard. Once you have the technique down, it's actually pretty fast. The shot of the Praying mantis above was shot in a real hurry. Light was fading, the creature was trying to scurry away and I had to go inside to get my camera and flash set-up. Luckily the mantis posed for me and then flew off. I got the shot because I knew what camera and flash setting worked at the distance needed. I got to make one adjustment and then fired off 3 shots before the mantis had enough of me jacking with him/her.
Chas Gordon
Mookalafalas
Gallery: 54 photos
Nov 22, 2010 03:03 |  #12
Ebay is great for the equipment. I bought a $16 flash bracket that works fine (it screws into the tripod mount of the camera), and paid about the same for an off-flash cable, and just 4 bucks or so for a little plastic-cloth diffuser that fits over the flash. If you have the equipment prepared ahead of time it shouldn't take more than a minute or two to change the lens and screw in the bracket (during the shoot, I mean).
gasrocks
Nov 22, 2010 08:51 |  #13
All you need to add to your equipment is one Canon 12mm ext. tube. Will give you what you need and will work on several of your lenses.
1,880 views & 0 likes for this thread, 7 members have posted to it.
Macro Possibilities
1592 guests, 137 members online
