It was going to happen because of where I live.. I had a shoot on yesterday morning and while inspecting my Tamron 28-75 I noticed fungus behind the front element.. This lens is six years old..
I still shot with it without any ill effects..
yogestee "my posts can be a little colourful" More info | Nov 21, 2010 19:51 | #1 It was going to happen because of where I live.. I had a shoot on yesterday morning and while inspecting my Tamron 28-75 I noticed fungus behind the front element.. This lens is six years old.. Jurgen
Randi Goldmember 1,106 posts Joined Dec 2009 Location: St. Louis, MO. More info | Nov 21, 2010 20:02 | #2 I purchased a 17-55 with a noticeable spot of mold, and trusted the seller when he told me that the spot had been there for a while and had dried and wouldn't expand or damage the lens, and he had no ill effects from it. Fortunately the seller was correct - the spot hasn't changed for as long as I've had the lens and doesn't affect the pictures at all. My experience isn't typical though... usually for most people, once any type of fungus is in the lens, it just gets worse.
JeffreyG "my bits and pieces are all hard" More info | Nov 21, 2010 20:31 | #3 What's the weather like in Laos? My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
At the moment warm and dry, until February.. Very hot and humid from March until October.. Jurgen
themadman Cream of the Crop 18,871 posts Likes: 14 Joined Nov 2009 Location: Northern California More info | Nov 21, 2010 22:18 | #5 You been a dry cabinet then! =P Not sure what they are really called, but those things where you can control humidity! Will | WilliamLiuPhotography.com
robonrome Goldmember 2,746 posts Likes: 2 Joined May 2008 Location: Australia More info | Nov 21, 2010 22:40 | #6 A big patch Jurgen or just a spot or two? rob - check my galleries at http://hardlightimages.zenfolio.com/
vinnie6756 Goldmember 1,075 posts Likes: 1 Joined Oct 2009 Location: 45° 6' 0" N / 87° 37' 50" W a.k.a - Marinette, WI More info | Nov 21, 2010 22:41 | #7 It's called a humidor...never would of thought to use one for a lens though!! themadman wrote in post #11324543 You been a dry cabinet then! =P Not sure what they are really called, but those things where you can control humidity!
Nov 21, 2010 23:11 | #8 robonrome wrote in post #11324615 A big patch Jurgen or just a spot or two? Rob,, one big bit about 3mm square and a few dots.. Jurgen
SaxonIV Senior Member 768 posts Joined Sep 2010 Location: Alabama More info | Nov 21, 2010 23:20 | #9 vinnie6756 wrote in post #11324621 It's called a humidor...never would of thought to use one for a lens though!! isnt a humidor what you use to keep cigars from drying out? that would do the opposite, well unless the 70% humidity in a humidor is still less than the outside which in that case yes you could use it.
robonrome Goldmember 2,746 posts Likes: 2 Joined May 2008 Location: Australia More info | Nov 21, 2010 23:21 | #10 yogestee wrote in post #11324737 Rob,, one big bit about 3mm square and a few dots.. bugger... maybe you can halt it by keeping in a box filled with silica gel, but I expect it will get worse once you get into the wet season. You use anything by way of special storage? Obviously don't want that to spread to the 135L rob - check my galleries at http://hardlightimages.zenfolio.com/
Nov 21, 2010 23:26 | #11 robonrome wrote in post #11324783 bugger... maybe you can halt it by keeping in a box filled with silica gel, but I expect it will get worse once you get into the wet season. You use anything by way of special storage? Obviously don't want that to spread to the 135L ![]() Or any other lens in my kit.. S'pose I'll put the 28-75mm into quarantine Jurgen
ajaffe Senior Member 792 posts Likes: 1 Joined Apr 2010 Location: San Diego More info | Nov 21, 2010 23:49 | #12 Couldn't you do the rice trick that people use for cell phones dropped in water? www.jaffe.photo
Mookalafalas Cream of the Crop More info | Nov 22, 2010 00:15 | #13 Here in Taiwan electronics shops all sell a kind of humidity controlling box that looks like a little refrigerator with a glass door in front. They are quite cheap, 100-200 bucks (depending on the size). You can also buy a plastic box that seals tight (also sold here in department stores/camera shops) when you close it and put a "water collector" in it (I don't know what they are really called, but Costco sells them. Its like a big cup with a permeable membrane over the top and its full of charcoal pebbles. Somehow it slowly begins to fill with water it pulls from the air). Call me Al Gear Flickr
themadman Cream of the Crop 18,871 posts Likes: 14 Joined Nov 2009 Location: Northern California More info | Nov 22, 2010 00:24 | #14 You want to be careful not to dry lenses out, their lubricant needs some moisture. If you put too many desiccant packets or something in a sealed bag or something it can have adverse effects on the lens. I remember hearing you don't want to get below 30% humidity or something along those lines. Will | WilliamLiuPhotography.com
Mookalafalas Cream of the Crop More info | Nov 22, 2010 00:40 | #15 themadman wrote in post #11324970 You want to be careful not to dry lenses out, their lubricant needs some moisture. If you put too many desiccant packets or something in a sealed bag or something it can have adverse effects on the lens. I remember hearing you don't want to get below 30% humidity or something along those lines. That's a good point. I actually have two of the refrigerator boxes, but use them for a stamp collection mostly (It's two floors away from my camera gear and I'm lazy:o. I think I have them set at 40% or something like that, actually, but I don't remember where I came up with that number. Call me Al Gear Flickr
| Latest registered member is semonsters 1464 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
