When I crop a image that is 18mg to a 8x10 and export to jpeg. Why would the file size at 650k. Export resolution is set to 100%.
extrememc Senior Member 597 posts Joined Oct 2005 More info | Nov 22, 2010 00:12 | #1 When I crop a image that is 18mg to a 8x10 and export to jpeg. Why would the file size at 650k. Export resolution is set to 100%. Photography is an expression of the mind!!!!!!!!!!!!!
tonylong ...winded More info | Nov 22, 2010 00:23 | #2 Well, we'd need more detail. A picture filled with clear blue sky will compress to a small image, whereas a picture with detail, not so much. If you can get a pic with a lot of detail and do the eport and it still comes out small, get back to us with posted examples, and you can also get the Raw file uploaded to a site like YouSendIt.com so we can check it out! Tony
Nov 22, 2010 00:33 | #3 tonylong wrote in post #11324966 Well, we'd need more detail. A picture filled with clear blue sky will compress to a small image, whereas a picture with detail, not so much. If you can get a pic with a lot of detail and do the eport and it still comes out small, get back to us with posted examples, and you can also get the Raw file uploaded to a site like YouSendIt.com so we can check it out! Here is a export of a 10mg file. The export was a virtual copy. Photography is an expression of the mind!!!!!!!!!!!!!
tonylong ...winded More info | Nov 22, 2010 01:38 | #4 OK, a lot of "open space" there, but to get really objective, can you post the Raw file at a place like YouSendIt.com? Tony
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | What are the PIXEL DIMENSIONS? Are you sure you're not resizing?
Nov 22, 2010 06:59 | #6 tonylong wrote in post #11325129 OK, a lot of "open space" there, but to get really objective, can you post the Raw file at a place like YouSendIt.com? What do you mean by "open space"? Photography is an expression of the mind!!!!!!!!!!!!!
Nov 22, 2010 06:59 | #7 egordon99 wrote in post #11325624 What are the PIXEL DIMENSIONS? Are you sure you're not resizing? " Export resolution is set to 100%." The compression level is a value from 1 to 100, so I suspect although you are using 100 for "quality", you have the resize checkbox checked.
Nov 22, 2010 07:00 | #8 I will try to post thru Yousendit today. Photography is an expression of the mind!!!!!!!!!!!!!
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Nov 22, 2010 07:37 | #9 extrememc wrote in post #11325780 Re size is not checked. Then how come the image is 1024pixels high? "I think the idea of art kills creativity" - Douglas Adams
Nov 22, 2010 18:39 | #10 Maybe it would help if I explain my workflow. Once in a catolog. I create smart collection for the sizes I need. Then I take and create VC of the image for the size I need, rate it and it goes in the the collection. From there I crop. If it's a 8x10 I create a custom crop then I export at 100% and 300 dpi. Photography is an expression of the mind!!!!!!!!!!!!!
tonylong ...winded More info | Nov 23, 2010 03:00 | #11 When you say you are exporting at 300 ppi, that indicates that you are resizing it. Go through your export options and de-select any resize options -- keep it to where your pixel dimensions are original and not set to "inches" and a ppi resolution. Tony
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Nov 23, 2010 03:11 | #12 What does your version say here?
The box should be unticked. "I think the idea of art kills creativity" - Douglas Adams
Nov 23, 2010 16:56 | #13 Photography is an expression of the mind!!!!!!!!!!!!!
tonylong ...winded More info | Nov 23, 2010 19:33 | #14 Well, it appears that either your original image is small or your crop was way too close. With the image open, you can go to the Library module and the Metadata panel and your crop dimensions should show as well as your original dimensions (you may need to pull down the list of viewing options next to the Metadata label and select All. Tony
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | Nov 23, 2010 19:48 | #15 tonylong wrote in post #11336024 From the looks of your Export panel what you are using is an image that is 1000x1000 pixels, whereas an uncropped out-of-camera image would be more along the lines of 2000x3000 for only a 6MP image (so it would be a size that matches your camera resoltion). . That was my thought too, but I fired up LR3 and in the Export dialog using an Export preset that doesn't resize, the dimensions in that box default to 1000x1000, even though they're "greyed out" if "Resize to Fit" isn't checked.
| Latest registered member is Frankie Frankenberry 1834 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
