Thread started 22 Nov 2010 (Monday) 13:12
Help with action shots, DOF issues?
JCJohnson
Nov 22, 2010 13:12 |  #1
I am just starting to learn how to shoot people and kids and it's tougher than I thought! I've been leaning on aperture priority but am still not getting what I want.
So what should I have done here? I realize my shutter speed is too low but I was afraid if I opened up my aperture anymore I'd lose depth of field and end up with some of them blurry. Is this purely a depth of field issue? I struggle with DOF. I saw a link someone posted regarding a calculator but I don't see that as feasible when actually out and about.
Thanks for the feedback. I'd really like to figure this out.
1/45 at f/8
focal length 85mm (new 85mm f/1.8 lens)
iso 800 (set on auto ISO)
Canon 40D; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.8 II; EF 50mm f/2.5 macro; EF85mm f/1.8 USM; EF 70-300mm f/4-5.6 IS USM
FlyingPhotog
Cream of the "Prop"
Nov 22, 2010 13:14 |  #2
1/45 is too slow a shutter speed to freeze your subjects. You've got motion blur from them walking as much as anything else.
Jay
Gatorboy
Nov 22, 2010 14:35 |  #3
Your subjects are in a line parallel to the lens. DOF isn't a problem. If you shot them one in front of the other, then you'd have to be a bit more concerned.
Opening up to f/2.8 would have given you plenty of shutter speed.
Dave Hoffmann
JCJohnson
Nov 22, 2010 16:00 |  #4
Thank you both for your input...you've definitely made my wheels turn. I went out today and played some more and figured some things out (like to get my son to be in focus when he's running around takes 1/250). I was blaming large aperture for fuzziness issues I had with other pictures I had taken but I think it must have been the AF point I had selected...so with that...
It all led me to my next question which is when you're doing these high speed shots do you just rely on the auto-selection for the autofocus mode? You have to right?
FlyingPhotog
Cream of the "Prop"
Nov 22, 2010 17:32 |  #5
Absolutely Not...
You're smarter than your camera and you need to tell it where you want focus to be.
Jay
AntonLargiader
Nov 22, 2010 17:56 |  #6
I think you're interchanging focus and blur. Focus is all about the lens being adjusted for the distance you are from the subject. That's a separate subject.
Blur can be several things including subject motion and camera shake. I think you have both of those in the first shot. 1/45 is very slow for most people to hand-hold, especially if it's an 'action shot' with the subject moving. When I look around that image I can't see any area that seems really crisp. So what I'm saying is I bet you have camera shake going on.
You also have some motion blur but I think it's not as bad. Walking is a fairly slow thing to do so feet and fingers are the place where you will see most of it. Probably 1/60 would improve it and 1/100 would really make a difference.
IS will help the camera shake and a faster shutter will help both. You might try using the the 70-300 (to get IS) since you're not taking advantage of the aperture on the 85.
Image editing and C&C always OK
Gear list plus: EF 1.4X II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
asysin2leads
I'm kissing arse
Nov 24, 2010 17:29 |  #7
FlyingPhotog wrote in post #11328690 (external link)
Absolutely Not...
Absolutely. I don't always use center point focus, especially wide open. I know what I want to focus on, the camera doesn't.
Here's one at 1/250th at f/2.8. He was actually running. As you can see, there is minimal motion blur in his arms to give the sense of motion, but his face is in focus and not blurry.
Kevin
https://www.google.com ….com&ctz=Americ​a/New_York (external link)
2,630 views & 0 likes for this thread, 5 members have posted to it.
1207 guests, 107 members online
