I was messing around tonight with a laser level and a ceiling fan and came up with the photos below. I used a laser level in "line mode" and moved it back and forth at different speeds across the fan.
1.
2.
3.
4.
5.
kb9tdj Senior Member More info | Nov 22, 2010 20:53 | #1 I was messing around tonight with a laser level and a ceiling fan and came up with the photos below. I used a laser level in "line mode" and moved it back and forth at different speeds across the fan. 2. 3. 4. 5. Scott
gearedforacure Member 144 posts Joined Mar 2009 Location: Omaha, NE More info | Nov 22, 2010 20:58 | #2 these are really cool! What I want To Buy: Zeiss ZF or ZE 35 F2.0
Shawnc Member 210 posts Likes: 5 Joined Jan 2008 More info | Nov 22, 2010 22:08 | #3 Now, can you process these like an IR photo? http://shawncarden.smugmug.com/
Titus213 Cream of the Crop More info | Nov 23, 2010 00:07 | #4 Fascinating! And well executed. Dave
maryhee Senior Member 439 posts Likes: 1 Joined Mar 2010 Location: Vancouver, BC More info | Nov 23, 2010 00:13 | #5 |
Anke "that rump shot is just adorable" UK SE Photographer of the Year 2009 30,454 posts Likes: 3 Joined Oct 2006 Location: Royal Tunbridge Wells, UK More info | Nov 23, 2010 00:25 | #6 That's really quite fascinating, nice one Anke
TekHouse Goldmember 1,289 posts Likes: 1 Joined Nov 2007 Location: Earth More info | Nov 23, 2010 16:31 | #7 |
PictureNorthCarolina Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info | This is really quite interesting, but I have a question. If you were doing this by hand (the laser), how did you make the shapes and lines so perfectly equal and concentric? When people do light painting by hand, it usually looks quite messy, but your sections / strokes here are perfect. (Well done, by the way!) Website
Nov 24, 2010 07:20 | #9 Beautiful work! Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
Nov 24, 2010 07:41 | #10 I was using a laser level which also can produce a line or cross-shaped beam in addition to a single laser point. For these shots I set up the unit to produce a line and then swept it across the fan just once during the exposure. By varying the rate at which I swept the laser line across the fan, I could produce different patterns. Picture North Carolina wrote in post #11337783 This is really quite interesting, but I have a question. If you were doing this by hand (the laser), how did you make the shapes and lines so perfectly equal and concentric? When people do light painting by hand, it usually looks quite messy, but your sections / strokes here are perfect. (Well done, by the way!) Scott
MHO Goldmember 1,406 posts Likes: 26 Joined Jun 2009 Location: Kingston, Surrey More info | Nov 24, 2010 08:28 | #11 this is awesome MHO Photography on Flickr
PictureNorthCarolina Gaaaaa! DOH!! Oops! 9,318 posts Likes: 248 Joined Apr 2006 Location: North Carolina More info | Nov 24, 2010 08:29 | #12 kb9tdj wrote in post #11338244 I was using a laser level which also can produce a line or cross-shaped beam in addition to a single laser point. For these shots I set up the unit to produce a line and then swept it across the fan just once during the exposure. By varying the rate at which I swept the laser line across the fan, I could produce different patterns. Ingenious! Website
rob_turner Mostly Lurking 13 posts Joined Oct 2010 More info | Nov 24, 2010 08:30 | #13 very cool indeed!
very nice creativity
tkerr Goldmember 3,042 posts Likes: 2 Joined Mar 2010 Location: Hubert, North Carolina, USA. More info | Nov 24, 2010 09:56 | #15 Very Imaginative. That is quite Cool. Tim Kerr
| Latest registered member is semonsters 1043 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
