Thread started 22 Nov 2010 (Monday) 21:13
Second Curtain Sync
css7493
Nov 22, 2010 21:13 |  #1
I am sure there will be many exceptions to the rule that chime in here, but . . .
I cannot believe I never knew about curtain sync, the second I randomly stumbled on it here and read about it it clicked instantly, I just can't believe I never knew it. A possible drawback to having no formal training I suppose. I can say one thing, it is going to do wonders for certain aspects of my work!
Gear
Quad
Joined Nov 2005
Nov 22, 2010 21:26 |  #2
Also a drawback to not reading the manual. You never know what wonders hide in the instruction booklet.
Nov 22, 2010 21:56 |  #3
once you go second, you never go back. So much better imo
--Jamie
Canon 1DX/Canon 16-35 2,8L/Canon 70-200 4L IS/Canon 24 1,4L II/Canon 50 1,8 II/Canon 15 2,8 Fisheye/
Website (external link) // Facebook Page (external link)
bobbyz
Nov 22, 2010 22:27 |  #4
1337. wrote in post #11330330 (external link)
For vast majority of flash application you rarely need 2nd curtain.
Fuji XT-1, 18-55mm
FlyingPhotog
Cream of the "Prop"
Nov 22, 2010 22:37 |  #5
Mine are permanently on Second Curtain sync with HSS enabled as well...
Jay
bobbyz
Nov 22, 2010 22:43 |  #6
FlyingPhotog wrote in post #11330573 (external link)
Again reason?
Fuji XT-1, 18-55mm
FlyingPhotog
Cream of the "Prop"
Nov 22, 2010 22:45 |  #7
bobbyz wrote in post #11330622 (external link)
Again reason?
If it's dark enough that I need flash, chances are I'll want any motion or streaks behind the subject and if I'm using flash for daylight fill, I'll want it in HSS anyways so that's where I leave things set.
Jay
Nov 22, 2010 22:58 |  #8
FlyingPhotog wrote in post #11330632 (external link)
my reasoning is the same, +1
--Jamie
PacAce
Joined Feb 2003
Nov 23, 2010 10:03 |  #9
Just don't be surprised when you take a flash picture at 1/60 and notice that the blur is not where you were expecting it to be for 2nd curtain sync. That's because 2nd curtain sync doesn't really kick in until 1/40 or slower (depends on camera model). :)
...Leo
TopHatMoments
Nov 23, 2010 10:41 |  #10
It is a good tool for mood lighting, allowing ambient light to set the stage, just before the flash kisses it.
Canon to PhotoShop, “Beam me up”! LR3 set course for CS5, Warp speed 64!___ ((dpp___/==***^***
ootsk
Joined Jan 2002
Nov 23, 2010 10:59 |  #11
TopHatMoments wrote in post #11333042 (external link)
How would the end result be any different if the flash went off first, then the ambient set the mood? I understand car headlights, etc. But for mood lighting, what's the net difference?
TopHatMoments
Nov 23, 2010 11:24 |  #12
Second curtain, allows the ambient to fill the scene. Then enough flash to stop movement, if there is any and add highlight to the shadows.
It does wonders for Christmas tree setting, fireside settings.
Second curtain is one of those things you can tech to death but, until you try it and see.
Depending on ambient light and flash power, you can set the ratios to overpower the surroundings, or just add a kick of fill and stop motion for a crisp
Tobi.
Nov 23, 2010 11:44 |  #13
TopHatMoments wrote in post #11333268 (external link)
First curtain can do that too, you know. Just select a longer shutter speed. With the same aperture, shutter time, ISO sensitivity etc., the only difference between first and second curtain is the direction the light streaks run.
Tobi
TopHatMoments
Nov 23, 2010 12:41 |  #14
And if people turn out fuzzy or not. I agree it can work with first. I do it that way also if the only light I want to control is my own.
As stated above it only comes into play at a certain shutter speed and slower.
It's kind of like automatic transmission. You can put it in low and shift up when you want or just put it in drive or OD and let it work itself out when it is needed.
PacAce
Joined Feb 2003
Nov 23, 2010 13:13 |  #15
TopHatMoments wrote in post #11333736 (external link)
If there is nothing in the motion that indicated any form of direction (forward or backward), then it doesn't really matter whether the shot is taken with 1st curtain sync or 2nd curtain sync. The effect on the resulting image will be similar (not the same, of course, but similar). I would even go as far as to bet that you would most probably not be able to identify which of the two images were taken with 1st curtain sync and which with 2nd curtain sync.
...Leo
4,520 views & 0 likes for this thread, 12 members have posted to it.
Second Curtain Sync
Latest registered member is Sandro Bisotti
1751 guests, 169 members online
