Thread started 23 Nov 2010 (Tuesday) 09:52
Linear Mode in DPP
yb98
Joined Feb 2003
Nov 23, 2010 09:52 |  #1
Do you use linear mode in DPP ? if yes :
1. why do you use it ?
1. when do you use it ?
3. how do you use it ? in particular how do you manage the curve ?
Any tips would be welcome. Thanks.
Best DPP Threads
DPP++ Video Channel (external link)
New Version DPP++ 11.3 released (external link)
tzalman
Fatal attraction.
Nov 23, 2010 10:48 |  #2
Yves -
I have on occasion used it to recover highlights by blending a linear conversion with a gamma corrected exposure, using only the highlights from the linear version. BreezeBrowser does this also, but I preferred to control the blend myself.
Elie / אלי
kirkt
Nov 23, 2010 11:05 |  #3
It is also helpful when using a raw converter to prepare images for HDR merge. If the raws need some sort of noise correction, white balance adjustment or other tweaking prior to merging, a linear response curve for the converted TIFF may be useful for the images to be merged.
I have also used a linear response curve for single raw image edits, where I do not want the arbitrarily applied "S" contrast curve, or gamma correction burned into the image data when I convert it to TIFF - i.e., I will control the luminance levels and contrast at a later stage in the PP.
Kirk
Kirk
1,337 views & 0 likes for this thread, 3 members have posted to it.
Linear Mode in DPP
1589 guests, 138 members online
