Thread started 24 Nov 2010 (Wednesday) 19:07
Dog green eye correction in LR3?
spotz04
Nov 24, 2010 19:07 |  #1
How do you fix a dog's green eyes from a flash in Lightroom 3?
Obviously the red eye tool doesn't work for this issue.
HappySnapper90
Nov 24, 2010 19:16 |  #2
As I've done with LR 2, try to get the red eye function to create an elipse.. somewhere. Then just move it to the green eye and resize the oval to match the green area like you would do a red eye where the auto function doesn't get it perfectly right.
tonylong
...winded
Gallery: 60 photos
Nov 24, 2010 19:40 |  #3
In Lightroom I'd use a local adjustment brush with settings for saturation and Exposure turned down and give it a try -- making the brush just the size of the green eye with a soft edge should give you something at least to play with. If it has a hard time targeting the color properly you can try the color picker to help the desaturation.
Give it a try!
Tony
jm2e
Joined Nov 2010
Dec 17, 2010 23:04 |  #4
Bump, 'cause there ain't much on the interwebz about this and the last two posts don't make any sense to me.
How do I correct yellow eye in mah dawg?
baccaruda
Dec 17, 2010 23:58 |  #5
duplicate the layer, hue/saturation adjustment to make green >> red, use redeye adjust, mask layer/delete all, unerase the eyes back in.. good luck!
tzalman
Fatal attraction.
Dec 18, 2010 04:23 |  #6
tonylong wrote in post #11341474 (external link)
Give it a try!
There is a trick to using the LA Brush with the Color Picker. Normally the brush adds a "layer" of color that blends with the original. E.g., paint blue on top of red and you get purple. But if Saturation (on the brush) is set to 0, the underlaying color becomes grey and therefore causes no hue shift. It will however, cause a luminosity shift from the color selected that can be adjusted with Exposure and/or Brightness.
Elie / אלי
tonylong
...winded
Gallery: 60 photos
Dec 18, 2010 06:28 |  #7
Give it a try!
tzalman wrote in post #11473194 (external link)
jm2e wrote in post #11472498 (external link)
So, have you tried playing with the things suggested, and learning about how they work? You do have to "read up" on the tools -- search Google about "lightroom brush tutorial" and such and try to get some experience about how things work!
Tony
spotz04
Dec 20, 2010 13:47 as a reply to  @ tonylong's post |  #8
I didn't get very good results in LR.
Instead I used Gimp, it seems much easier for a single pic correction ----select green in eyes using Fuzzy Select tool. Then Select-> Grow by 1 pixel. Apply Desaturate. Finally adjusted in the Levels dialog to darken the eye color.
tonylong
...winded
Gallery: 60 photos
Dec 20, 2010 16:15 |  #9
What did you actually try in Lightroom that didn't work?
Tony
Mosephus
Joined Sep 2009
Dec 20, 2010 17:46 |  #10
Ditto, take your brush and desaturate the reflective part of the eye, and then lower the exposure/brightness to get rid of the shine.
IMAGE: http://i128.photobucket.com/albums/p193/M715/DSC_0276.jpg
IMAGE: http://i128.photobucket.com/albums/p193/M715/6ee39577.jpg
Dallas Pet Photography (external link)
chauncey
Dec 20, 2010 18:33 as a reply to  @ Mosephus's post |  #11
Nathan has it right, it's a learned, practiced, skill...provided ya want to bother with the learning and practicing part.
HappySnapper90
Dec 20, 2010 21:56 |  #12
If you use Lightroom, use the red eye removal feature. Click on something in the photo to try to get it to place an oval. Then move the oval to your dog's eyes and click and drag it to enlarge it to cover the eye. It will work, I've done it for a dog's eye myself.
5,997 views & 0 likes for this thread, 8 members have posted to it.
2879 guests, 134 members online
