Thread started 24 Nov 2010 (Wednesday) 19:25
Bridge bug?
D ­ Thompson
Nov 24, 2010 19:25 |  #1
Running CS5 Bridge (4.0.3.9) on Win XPPro. When I select a few files, right click, choose Move to, select a folder, click ok, and Bridge crashes and shuts down. The files get moved to the new folder, but it crashes whether I use that method, drag & drop, or use File>Move to. Does this work for anyone else?
Thanks.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
tonylong
...winded
Gallery: 60 photos
Nov 24, 2010 19:46 |  #2
I don't have CS5 and I typically do that type of thing in Lightroom, but just something to try: What happens if you slelect the images and then rather than right-click the images you right click on the target folder? Does it have an option to move the files into that folder?
Tony
D ­ Thompson
Nov 24, 2010 19:49 |  #3
tonylong wrote in post #11341506 (external link)
It selects the folder, but de-selects the files.
Dennis
tonylong
...winded
Gallery: 60 photos
Nov 24, 2010 20:00 |  #4
Hmm, well, I'm out of ideas!
Tony
D ­ Thompson
Nov 24, 2010 21:05 |  #5
Anybody have CS5 willing to try this and see what happens?
Dennis
MNeuls
Nov 25, 2010 00:09 as a reply to  @ D Thompson's post |  #6
Hi D,
no problems here, at all, with same Bridge build and Win 7 64bit.
Regards
Martin
D ­ Thompson
Nov 25, 2010 06:50 |  #7
MNeuls wrote in post #11342730 (external link)
Hi D,
Regards
Martin
Thanks Martin for taking a couple of minutes to check it. Is it just you and me with CS5?:rolleyes:
I checked on the Adobe forum and found a few things to try.
Dennis
ChasP505
"brain damaged old guy"
Nov 25, 2010 12:37 as a reply to  @ D Thompson's post |  #8
Does it happen when you simply drag the files? When moving files in Bridge I always drag and drop. Never crashes.
Chas P
TTk
Nov 25, 2010 12:44 as a reply to  @ ChasP505's post |  #9
Just checked mine and all ok which ever way I move them..
Terry.:cool:
http://www.terrykirton.co/ (external link)
http://www.ttkphotogra​phy.com/ (external link)
http://www.langtoftpho​tography.com/ (external link)
 (external link)
tonylong
...winded
Gallery: 60 photos
Nov 25, 2010 14:20 |  #10
I don't know how these things are OS-dependent and how may are PS dependedt. For example, how does the Cache interact with moving folders and files? If that could be a cause of problems you could try purging the Cache and see if that frees something up?
Tony
D ­ Thompson
Nov 25, 2010 20:34 |  #11
ChasP505 wrote in post #11344899 (external link)
It doesn't matter whether I drag & drop, right click>move to, or File>Move to.
TTk wrote in post #11344924 (external link)
Thanks for checking.
tonylong wrote in post #11345265 (external link)
It didn't help purging the cache.
I've opened a ticket with Adobe on the issue. I found the same issue with an earlier version of CS5 Bridge and was supposed to be fixed, but evidently it didn't make the 4.0.3.9 update. According to a response - disabling the startup scripts and then terminating a certain process would isolate it. I tried it and it still did. Guess I'll have to wait for Adobe.
Thanks.
Dennis
magwai
Nov 26, 2010 03:38 |  #12
get the files where you want them using a regular file explorer. edit them using bridge/photoshop. simples.
it does illustrate just how badly written adobe software is, that it can crash on such a trivial operation.
D ­ Thompson
Nov 26, 2010 13:19 |  #13
magwai wrote in post #11347631 (external link)
While there are certain instances I do that, it'd be in pita to do it all the time. I don't use the Move option often, but would like it to work.
Dennis
D ­ Thompson
Nov 26, 2010 13:21 as a reply to  @ D Thompson's post |  #14
Could someone with CS5 check if you have the following file?
\Documents and Settings\[User name]\Application Data\Adobe\Adobe Bridge CS5 \Adobe Bridge CS5 Settings\Adobe Bridge CS5 Prefs.psp
The only ....Prefs.psp I can find is under Adobe Photoshop CS5 folder.
Thanks.
Dennis
2,693 views & 0 likes for this thread, 6 members have posted to it.
Bridge bug?
1131 guests, 133 members online
