Thread started 25 Nov 2010 (Thursday) 22:16
70-200 F4 Question
cokethenwpepsi
Nov 25, 2010 22:16 |  #1
I just have a few questions on the 70-200 F4L (non IS) lens:
1 (the obvious): Is the IQ a noticeable improvement over the EF 70-300 F4-5.6 IS USM?
and
2: Does the lack of dust-resistance cause recurring problems?
Thanks for any and all input.
Alex
5D2 | 7D | 70-200 f/4L IS | 85 f/1.8 | Sigma 35 f/1.4 | 50 f/1.8 | 430 EX II
xarqi
Nov 26, 2010 01:06 |  #2
I'm going to go with:
Yes (assuming IS isn't essential), and
No.
K6AZ
Nov 26, 2010 01:25 |  #3
The IQ of the 70-200mm non-IS makes the 70-300mm look like a kit lens. They also work very well with several 1.4x TCs making it a 98-280mm lens.
halitime
Nov 26, 2010 02:52 |  #4
No Dust with mine.
Gear List : 1D MK II n,Gripped XSi,70-200 f4,300 f4 IS,Canon 24-105 f4,35 f2 IS,EF 50 1.8 MK I,EF-S 10-22,Canon 1.4 II Extender,Canon 25mm Ext Tube,YN 468/460 II,RF 602's
http://www.flickr.com/​photos/halitime/sets/ (external link)
tkbslc
Nov 26, 2010 02:54 |  #5
K6AZ wrote in post #11347402 (external link)
The IQ of the 70-200mm non-IS makes the 70-300mm look like a kit lens. .
I've seen many reviews counter to this claim...
Taylor
EOS Rp | iPhone 11 Pro Max
cokethenwpepsi
Nov 26, 2010 08:26 |  #6
Ok, very reassuring to hear that the dust is not a problem.
Some say the IQ blows the 70-300 away, others say the two are very comparable...What's the majority opinion?
Alex
Invertalon
Nov 26, 2010 08:36 as a reply to  @ cokethenwpepsi's post |  #7
For me, no contest. The 70-200 was a much better lens. I had upgraded from the 70-300 and it is that much beter.
-Steve
Facebook (external link)
K6AZ
Nov 26, 2010 10:50 |  #8
tkbslc wrote in post #11347561 (external link)
This isn't a claim. It is hands on experience with both.
tkbslc
Nov 26, 2010 11:06 |  #9
K6AZ wrote in post #11348635 (external link)
And what do you think reviews are?
Taylor
K6AZ
Nov 26, 2010 11:23 |  #10
tkbslc wrote in post #11348717 (external link)
A lot of them are skewed. I've shot and owned both side by side. Have you? Or are you basing your opinion on review sites?
RPCrowe
Joined Nov 2005
Nov 26, 2010 13:48 |  #11
I have shot with both lenses and, while I don't think the "L" lens actually blows the non-L away, I do consider it a significantly better lens.
The constant f/4 aperture at 200mm beats the heck out of an f/5.6...
The front element of the "L" lens doesn't rotate which facilitates the use of a CPL filter...
The "L" lens is built like a tank. I fell with the lens hood of the 70-200mm lens hitting the cement propelled by my 200+ pounds of beef. The hood was toast but the lens escaped without any harm. Peraps this could also happen with the 70-300mm but, I really doubt it. BTW - if anyone wants to duplicate this accident, please let me know the results of the experiment.
That said, I far prefer the (more expensive) IS model of the 70-200mm f/4L lens to either the 70-300mm or the non-IS 70-200mm... I had the non-IS model and I use the non-IS 4-5x more often because of my ability to hand hold this lens.
pcj
Nov 26, 2010 13:52 |  #12
Non IS 70-300 was replaced with the non IS 70-200 f/4 L and I couldn't be happier. Considerably better lens all around.
7D (gripped) | GoPro Hero HD | Canon 70-200mm f/4 L | Tamron 28-75mm f/2.8 | 40mm f/2.8 | 85mm f/1.8 | 28mm f/1.8 | 3 * 600EX-RT - All gear
http://www.rt2photo.co​m (external link)
http://www.facebook.co​m/rt2photo (external link)
K6AZ
Nov 26, 2010 13:58 |  #13
RPCrowe wrote in post #11349430 (external link)
I'll add a couple of things to your observations. I found the 70-300 to be a little soft beyond 200mm and the AF would hunt in lower light especially when I would try to get a bird in a tree when it would be cloudy. It's not a horrible lens like the 75-300 but I would rate it along the lines of a good kit lens.
As far as the IS/non IS versions of the 70-200, I now own the IS version. I would have held on to the non-IS if I hadn't picked up the IS in a package deal. As far as I can tell the difference is in the IS which comes in very handy such as the bird in the tree situation when it's overcast.
cokethenwpepsi
Nov 26, 2010 14:16 |  #14
Thank you everybody for the input.
I've been wanting to upgrade my 70-300 for a while; I've been slowly replacing my non-L lenses that I purchased when I first got into digital photography with L lenses. First I replaced my kit EF-S 18-55 with the 17-40 F4L and I couldn't be happier with that upgrade. But since I mostly shoot sports, I wanted to buy a top-quality telephoto lens to replace my 70-300. I've been more than happy with a lot of the images that I've been able to capture with that lens, as I brought it to high school soccer, softball, baseball and lacrosse games, as well as cross country and track meets. As long as the light was bright, the AF had no problem focusing quickly and I was able to get the shutter speed up high enough even with the aperture limited to f5.6 at the tele end. However, as my photographic eye developed with time, and I got pickier and pickier, I, too, noticed that the images were slightly soft at the 200+mm range. For this reason, along with the variable aperture (and partially the lack of a red ring), I felt it was necessary to replace this lens next.
After doing some extensive research, reading handfuls of reviews on various websites, and some opinions from local photographers, I ordered the lens this morning, and it should be here early next week. Thanks for all the input!
Alex
K6AZ
Nov 26, 2010 14:21 |  #15
cokethenwpepsi wrote in post #11349558 (external link)
I think you will be happy with it. Also you may want to consider a 1.4x TC. If you don't like the price of the Canon version there are several third party versions that work very well. I have a Tamron 1.4x TC I picked up on eBay for $84 and I have a hard time telling the difference between it and the Canon TC.
3,833 views & 0 likes for this thread, 18 members have posted to it.
70-200 F4 Question
1370 guests, 184 members online
