match14 wrote in post #11362633
Another couple of questions does input sharpening effect resizing? I.e. if you want to resize an image to 900x657 do you have to use more/less input sharpening, does final size effect output sharpening i.e. for small size use high/low sharpening.
The other way around, downsizing effects sharpness, reducing it. That is why LR has two levels of overall sharpening; capture (input) sharpening in the Develop module which is intended to only be partial sharpening, just enough to cancel out the effect of the camera's AA filter, and output sharpening in the Export dialog which is interactive, adjusting itself to vary the sharpening according to the amount of resizing.
