FORUMS Photography Talk by Genre Critique Corner
Thread started 26 Nov 2010 (Friday) 19:26
need help
musso
Nov 26, 2010 19:26 |  #1
i have this image i dont know what caused this. i used every setting i could think of but i could not get it. please let me know what to do to fix it. i was in a shady aera.
1/50 @6.3
31mm
iso 100
GorgeShooter
Nov 26, 2010 19:32 |  #2
What image??
1DX | 5D MkII (gripped)
16-35 f/2.8L | 24-70 f/2.8L | 24-105 f/4L IS | 70-200 f/4L IS | 100-400 f/4.5-5.6L IS | 24 f/3.5L TS-E | 45 f/2.8 TS-E | 40 f/2.8 Pancake | 15 f/2.8 Fisheye | Tokina 100 f/2.8 Macro | Canon 1.4x TC | 580 EX II | 430 EX II | Manfrotto 055CXPRO4 | Kirk BH-1
:: Smugmug :: (external link) | :: Photography BLOG :: (external link) | :: Workshops and Classes (external link) ::
kjonnnn
Nov 26, 2010 22:31 |  #3
Are you speaking of the blue cast? If that's it, images take in the shade on a sunny day have a blue cast. You eyes adjust for it, but the camera doesn't. Add some warmth to it either in raw, or color balance in post.
robertn
Nov 27, 2010 04:06 |  #4
Drop the aperture number and bump up the iso for correct exposure as well.
Canon camera, lenses & lights.
www.RobertNabbe.com (external link)
richcon
Nov 27, 2010 08:36 |  #5
Also check your white balance. The tungsten setting can give a blue cast as well. And as said above your aperture seems a bit high. Try that :)
Looking for Fuji X100F
Titus213
Nov 27, 2010 08:57 |  #6
I would expect the snow is exposed quite well. Add some exposure compensation to compensate for it.
Dave
Perspiring photographer.
Tydus
Joined Nov 2010
Nov 27, 2010 09:53 |  #7
bump up the iso next time. and see if it works..
FrontElement
Nov 27, 2010 10:36 |  #8
was it shot in RAW or JPEG?
quite a lot can be done in lightroom to fix this image
can you post a bigger size of the image? maybe we can then attempt at some PP to see what we can fix
if you have a flash,
use it as fill flash, and expose for the snow so you wont lose the details in the snow, yet get a perfectly lit subject, it might take some time to balance these two if
you didn't do it before
My Gear : 5D MKII, 24-70mm f/2.8L, EF 70-200mm F2.8 L IS II USM, EX580II
musso
Nov 27, 2010 13:29 |  #9
it was shot in raw.i will try to upload a bigger image when i get home.
thnak you
joe
kjonnnn
Nov 27, 2010 14:06 |  #10
An easy way to fix this photo.. is to, in either curves or level, choose the eyedropper to the right. Then select the WHITEST part of the snow. Click OK. This selects your white balance. But also be careful, because whatever area you select is to be the absolute whitest part (pixel) of the image. If you dont select what is to be the whitest part, it will "overexpose" the rest of the image.
989 views & 0 likes for this thread
need help
Latest registered member is le bleu
590 guests, 342 members online
