Thread started 27 Nov 2010 (Saturday) 18:53
Focus At What Distance When Shooting Reflection In Mirror?
TomBrooklyn
Nov 27, 2010 18:53 |  #1
What is the correct distance at which to manually preset focus, to photograph a reflection of something (somebody) in a mirror?
What is the effect, if any, of the plane of the camera's sensor not being parallel with the mirror? i.e. shot at an angle to the mirror, not straight on.
I cannot see the subject, because I will be the subject (self portrait), and I won't be behind the camera when photographed. I will have the camera tripod mounted and will fire it remotely.
I could figure it out by trial and error, but I'd like to know any applicable theory and the theoretically correct distance anyway.
adam8080
Nov 27, 2010 18:55 |  #2
How far does the light travel to get to the camera?
Huntsville Real Estate Photography (external link)
sandpiper
Nov 27, 2010 19:21 as a reply to  @ adam8080's post |  #3
Add up camera to mirror and mirror to subject distances, you are effectively shooting something an equal distance 'behind' the mirror as the subject is in front of it.
Easiest way would be to place something where you intend to be and focus on it, then simply take it's place and fire the shot.
TomBrooklyn
Nov 27, 2010 22:28 as a reply to  @ sandpiper's post |  #4
OK. Cool. Thanks. I'll probably measure it out with a tape measure.
Sorarse
Nov 28, 2010 06:08 |  #5
The easiest way would be to stand something on the spot you will be standing, and use that to set the focus on your camera. But Sandpiper is right if you want to measure it. It's the combined distance of camera to mirror and mirror to subject.
At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
http://www.scarecrowim​ages.com (external link)
Canon PowerShot G2
gkuenning
Joined Jan 2005
Nov 28, 2010 06:19 as a reply to  @ Sorarse's post |  #6
It doesn't matter if the sensor is parallel to the mirror. The only thing that matters is if the sensor is parallel to the subject's reflection. In other words, let's say you put your camera to the right of the mirror, with the sensor at a 30-degree angle. To be seen, you'll need to stand at the left. If the left (farther from the camera) side of your body is closer to the mirror, and you yourself are at a 30-degree angle, the sensor will be parallel to your reflection and everything will be in focus.
Geoff
All I want is a 10-2000 f/0.5L with no distortion that weighs 100 grams, fits in my pocket, and costs $300. Is that too much to ask?
2,499 views & 0 likes for this thread, 5 members have posted to it.
1060 guests, 104 members online
