Thread started 28 Nov 2010 (Sunday) 15:22
May have learnt how to use Iris
naddieuk
Nov 28, 2010 15:22 |  #1
I think I have found out how to use Iris to remove light pollution.
I used the tutorial here: http://www.boltonastro​.org.uk/Forums/viewtop​ic.php?f=4&t=60 (external link)
I started from the Processing your image section. It is a stack of 12 lights and 11 darks.
This is my attempt at capturing the area around Sadr last night.
I know the stars are a bit oval, I left the timing on 8 seconds instead of 6 by mistake. It was taken at 1600 ISO, above the 350D's recommended. 55mm kit lens. I think the cold weather has improved the seeing conditions. If only the lights were out.
Canon Powershot S95, Canon EOS 1000D attached to Skywatcher Explorer 150P on an EQ-3 unguided mount.
My Flickr site. (external link)
Edsport
Nov 28, 2010 22:11 |  #2
If you have photoshop you could try this to remove light pollution http://galacticfool.co​m …ight-pollution-photoshop/ (external link)
and this to remove uneven field illumination http://www.astropix.co​m/HTML/J_DIGIT/VIGNET.​HTM (external link)
Cameras - Canon 350D, 5D
Lenses - Canon 18-55mm, 75-300mm, 50mm f/1.8, 24-105L, 24-70L
Flashes - Yongnuo YN460 II, YN468
RF-602 transmitter and 2 receivers
naddieuk
Nov 29, 2010 03:00 as a reply to  @ Edsport's post |  #3
Thanks for the suggestion. I have used the method in Galactic Fool, but I found it very time consuming. I have found that Iris has a simple one step function that does both functions in one go. There is a more advanced version, but I think the way shown in that tutorial seems easy enough. I only dealt with the Gradient removal (polynomial).
I will try the other techniques once I have more time.
1,107 views & 0 likes for this thread, 2 members have posted to it.
1360 guests, 188 members online
