Has anyone used a ramdisk with LR3 to make it run faster (particularly in the Develop module)? If so, can you share how you did it?
I have a Windows 7 64-bit machine with 12GB of RAM, so I am willing to give up 4GB or so for a ramdisk. Thanks.
JChin Senior Member 415 posts Likes: 1 Joined Jul 2004 Location: New York City More info | Nov 30, 2010 03:44 | #1 Has anyone used a ramdisk with LR3 to make it run faster (particularly in the Develop module)? If so, can you share how you did it? Johnny J. Chin ~ J. Chin Photography
citro Member 167 posts Joined Sep 2008 Location: Bucharest, Romania More info | Nov 30, 2010 04:31 | #2 My thoughts on the issue: Canon 400D :: Tamron 28-75mm f/2.8 :: Canon 70-200mm f/2.8L :: Tokina 12-24mm f/4 :: Speedlites :: Flickr
Nov 30, 2010 04:33 | #3 Which is the RAW cache directory? How do you tell LR3 to put it somewhere else? Johnny J. Chin ~ J. Chin Photography
citro Member 167 posts Joined Sep 2008 Location: Bucharest, Romania More info | Nov 30, 2010 06:14 | #4 File Handling tab in Edit - Preferences Canon 400D :: Tamron 28-75mm f/2.8 :: Canon 70-200mm f/2.8L :: Tokina 12-24mm f/4 :: Speedlites :: Flickr
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | Nov 30, 2010 06:51 | #5 When I built my latest system I tried using SuperSpeed Ramdisk Pro to create a Ramdisk and I didn't notice any appreciable increase in performance. Albeit, I don't recall trying Lightroom but I did use Photoshop. I edit extremely large, layered files and I didn't see the expected speed increase. With large amounts of RAM on a 64-bit system the app doesn't swap files to your hard drive as it would with a 32-bit OS. I ended up removing the Ramdisk and software.
Dec 01, 2010 05:16 | #6 PixelMagic wrote in post #11368992 When I built my latest system I tried using SuperSpeed Ramdisk Pro to create a Ramdisk and I didn't notice any appreciable increase in performance. Albeit, I don't recall trying Lightroom but I did use Photoshop. I edit extremely large, layered files and I didn't see the expected speed increase. With large amounts of RAM on a 64-bit system the app doesn't swap files to your hard drive as it would with a 32-bit OS. I ended up removing the Ramdisk and software. Thanks for that info. I guess you just saved me a lot of time. Johnny J. Chin ~ J. Chin Photography
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Dec 01, 2010 15:09 | #7 If you put the cache on RAM disk you need to regenerate it every time you look at the images, unless it's somehow persistent. 4GB is pretty small for a ram disk too. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
tonylong ...winded More info | Dec 01, 2010 16:53 | #8 tim wrote in post #11377635 If you put the cache on RAM disk you need to regenerate it every time you look at the images, unless it's somehow persistent. 4GB is pretty small for a ram disk too. Hmm, good info, Tim, and enough to give someone second thought, especially since it can help performance to enlarge the Camera Raw/LR cache to larger. Tony
| Latest registered member is semonsters 1472 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
