Thread started 30 Nov 2010 (Tuesday) 15:36
Should I get another Elinchrom D-Lite 4?
DANG_BLUE
Nov 30, 2010 15:36 |  #1
I'm going to setup a small studio 4,5m x 6,5m x 3,5m
Having an D-lite 4 To Go Set, I consider to buy 2 more lights.
Should I buy another D-Lite 4/ D-Lite 2 or BX Ri 500 set or save to get monolights like QUADRA, RX?
Fureinku
Nov 30, 2010 16:15 |  #2
just fyi... quadra, rx arent monolights, d-lites are...
id go for d-lites.. for money saving.. unless what you shoot requires the benefits of pack/head setups
Gear List | Wish List |
DANG_BLUE
Dec 01, 2010 14:28 as a reply to  @ Fureinku's post |  #3
Is the BX Ri worth the money compare to D-lite 4?
aaron.dunlap
Dec 01, 2010 16:17 |  #4
DANG_BLUE wrote in post #11377398 (external link)
They come with a built in skyport, so if that is your triggering system then you can avoid buying another receiver by going with the BX Ri's....
 Aaron
TMR ­ Design
Joined Feb 2006
Dec 01, 2010 16:26 |  #5
Fureinku wrote in post #11371840 (external link)
The RX series certainly are monolights. There's a 300RX, 600RX and 1200RX. Then there is the Ranger RX series packs.
Robert
DANG_BLUE
Dec 02, 2010 14:55 as a reply to  @ TMR Design's post |  #6
The saler at Elinchrom store has advised me to buy another D-lite 4 instead of BX Ri 500/500.
I wonder if D-lite 4 (25-400Ws) and BX Ri 500 (31-500Ws) are too much power for my small studio.
The problem is the price of BX Ri 500/500 Set now is cheaper than BX Ri 250/500 Set because of discount on 500/500 :(
DANG_BLUE
Dec 07, 2010 13:08 |  #7
Now I consider between:
1. Buy 500/500 Set
2. Buy 2/4 DliteIT Set + octa 135 + 2 x reflector 21cm (for background)
What should I do?
sigma ­ pi
Dec 07, 2010 13:24 |  #8
I have the 500/500 and yes its probably too much power for a small room. I am shooting at f11 or more on the lowest setting. But they are great when going against the sun.
Don't try to confuse me with the facts, my mind is already made up.
http://www.flickr.com …6850267535/in/p​hotostream (external link)
sdipirro
Dec 07, 2010 13:41 |  #9
sigma pi wrote in post #11411300 (external link)
Huh? I have a pretty small home studio and use a pair of 600RX's for my main and fill (plus 1-3 Dlite-4's for background and hair/accent lighting). Even when just using my two 600RX's, I'm not getting f11 at the lowest settings. I'm often using medium to large octas with diffusers for modifiers, but I might have one light set to 3.5 and another set to 2.5 to get f8-f11.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
DANG_BLUE
Dec 08, 2010 15:29 |  #10
Is Flash Duration (1/800 of D-lite4 vs 1/5000 of BXRi500) is a big problem to photograph people jumping?
kokakaste2
Dec 08, 2010 15:53 |  #11
DANG_BLUE wrote in post #11418214 (external link)
Its more like 1/1500, but yeah the faster the duration the better freezing capabilities the strobe have. :)
Oskar (Oscar) - stuff I use- Flickr (external link) - My Facebook page (external link) :)
DANG_BLUE
Dec 08, 2010 16:15 |  #12
kokakaste2 wrote in post #11418320 (external link)
Sorry, I mean 1/1500 :D
But 1/800 vs 1/1500 is much different for shooting jumping people?
kokakaste2
Dec 08, 2010 16:25 |  #13
Dunno don't have either of them, but sometimes the Quadra 1/3000 is not enough to freeze flying objects :) depends how fast the action is. If you have Elinchrom shop near by go and visit them, try them out :)
spacetime
Dec 08, 2010 21:24 |  #14
DANG_BLUE wrote in post #11418463 (external link)
I've found it to make a significant difference. However, I had the person spinning instead of jumping and the faster flash duration reduced motion blur quite a bit. Since you have a Dlite4 try taking a photo and see if the flash duration suffices. If not then consider the BXRi.
DANG_BLUE
Dec 18, 2010 17:30 |  #15
emitecaps wrote in post #11419945 (external link)
I've tried shooting jumping model with Dlite-4. The result was quite blur, especially at hands and legs. But I still went for another D-lite Set instead of BXRi because I can add 135cm octa, 2 x 21cm reflector, honeygrid.
Thank you.
5,002 views & 0 likes for this thread, 8 members have posted to it.
1190 guests, 122 members online
