Thread started 30 Nov 2010 (Tuesday) 17:26
Too much power
Aleness
Nov 30, 2010 17:26 |  #1
As I don't have a studio yet and shooting most of my portraits and whatnot in a close quarters of my apartment, I ran into a problem of too much light.
I have a 24"x24" softbox mounted on JTL 160 and even when it's dialed all the way down to 1/8 of the power, I have to shoot at f5.6 or even higher f-stop. The softbox is 2-3 feet from a subject.
One of the ways I know is to use an ND filter (or even stack a couple).
When I move the softbox away it becomes harder to control the light and I don't really have that much room. I can probably move it back to 5-6 feet, but then it's still too bright.
Do you guys have any suggestions on what I can do here?
Thanks a bunch,
Aleness
Bunnies will rule the world!
Websiteexternal link | Gear List & Feedback
Fureinku
Nov 30, 2010 17:50 |  #2
whats the issue with shooting higher fstop?.. esp indoors where background may be irrelevent other than color.. unless you are shooting without a backdrop and want the background blurred
otherwise, you might try going to a fabric store, or using white bed sheets to stack on the front of the softbox.. more diffusion panels = less light
Gear List | Wish List |
Hoppy1
Nov 30, 2010 18:52 |  #3
Best way is an ND filter on the lens.
5D2, 17-40L, 50/1.8, 24-105L, 70-200L 4 IS, 580/270EX, Strato II/RF-602, Elinchroms
Aleness
Nov 30, 2010 19:10 |  #4
Which ND filters are you referring too. I have a Cokin ND3 for the lens (which is probably not enough).
I've seen some gels are sold for the light, but not the ND filters.
Something like the set here (external link) closer to the middle of the page?
Jim ­ M
Nov 30, 2010 22:03 |  #5
I'm with Fureinku. I suppose it's a matter of taste, but I'd prefer to shoot portraits against a plain background at around f/8 or 11.
xcel730
Dec 01, 2010 10:00 as a reply to  @ Jim M's post |  #6
Paraphrasing from Zack Arias' OneLight DVD:
Sometimes you just have too much light ... you could either put ND filters on your lens or strobe or you could use a lower power speedlight.
________
[Gear List]
Quote: If the grass is always greener on the other side, then maybe you should start working on your own grass.
Hoppy1
Dec 01, 2010 14:09 |  #7
xcel730 wrote in post #11375857 (external link)
Or, if you have studio strobes and want to use a very low f/number for shallow DoF, then disconnect the sync and shoot with just the modelling bulbs. They're usually plenty bright enough for f/2 or so, and adjustable on most heads.
White balance to tungsten, or custom WB.
Aleness
Dec 01, 2010 14:57 |  #8
Hoppy1 wrote in post #11377289 (external link)
Modeling light on JTL 160 isn't adjustable, but I like the idea. It will allow me to shoot at even 1.4 easily.
I'm gonna try that tonight. :)
1,710 views & 0 likes for this thread, 5 members have posted to it.
Too much power
1459 guests, 133 members online
