So to shoot wide open in the daylight using a 580ex II at HSS I need buy zebra flash ettl cord? I am wanting to start using fill flash during my outdoor portraits but my strobes won't sync at high shutter speeds when I shoot wide open.
ProjectNineFive Member 151 posts Likes: 5 Joined Jun 2010 More info | Dec 02, 2010 00:19 | #1 So to shoot wide open in the daylight using a 580ex II at HSS I need buy zebra flash ettl cord? I am wanting to start using fill flash during my outdoor portraits but my strobes won't sync at high shutter speeds when I shoot wide open. Project Nine Five Photography
davidlacey Senior Member 968 posts Likes: 1 Joined Sep 2010 Location: Colorado More info | Dec 02, 2010 01:02 | #2 ProjectNineFive wrote in post #11380622 So to shoot wide open in the daylight using a 580ex II at HSS I need buy zebra flash ettl cord? I am wanting to start using fill flash during my outdoor portraits but my strobes won't sync at high shutter speeds when I shoot wide open. Trying to understand you have strobes and want to shoot wide open the right ND filter could fix assuming strobe has enough power
24Peter Senior Member 821 posts Likes: 1 Joined Nov 2005 Location: Dover, NJ More info | Dec 02, 2010 09:27 | #4 ProjectNineFive wrote in post #11380622 So to shoot wide open in the daylight using a 580ex II at HSS I need buy zebra flash ettl cord? I am wanting to start using fill flash during my outdoor portraits but my strobes won't sync at high shutter speeds when I shoot wide open. Well you could also sync at your strobes' normal speed and use ND filters to allow you shoot wide open. You just need enough juice from the strobes... Nikon D850/D750
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Dec 02, 2010 09:53 | #5 Cord might be cheaper than the ND filers though based on what size filters you lookin for. With filters you will still need the cord to get the flash off camera. All depends on what you plan to shoot and what time of the day. Fuji XT-1, 18-55mm
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Since the OP wants to use a Speedlight off camera and make use of ETTL and HSS, the off shoe cord is needed. I would assume that the OP doesn't have any method of accomplishing this with a wireless system. Robert
Eruditass Member 46 posts Joined Oct 2010 Location: Laurel, Maryland More info | Dec 02, 2010 11:36 | #7 24Peter wrote in post #11382015 Well you could also sync at your strobes' normal speed and use ND filters to allow you shoot wide open. You just need enough juice from the strobes... HSS will use more power than using an ND filter by nature. ND filters will always be more efficient. I'm always striving to improve. Any sort of constructive critique, no matter how minute or harsh, is appreciated.
charlesml3 Member 245 posts Joined Oct 2008 More info | Dec 02, 2010 12:35 | #8 HSS will use more power than using an ND filter by nature. ND filters will always be more efficient. That's good to know. I almost bought a linear polarizer but it had a knob on the side that wouldn't work with my lens hood. I kinda like my hood...
24Peter Senior Member 821 posts Likes: 1 Joined Nov 2005 Location: Dover, NJ More info | Dec 02, 2010 13:52 | #9 TMR Design wrote in post #11382339 Since the OP wants to use a Speedlight off camera and make use of ETTL and HSS, the off shoe cord is needed. I would assume that the OP doesn't have any method of accomplishing this with a wireless system. An ND filter would certainly be a good solution but if 'inexpensive' is the objective then it makes sense to use a long off shoe cord for ETTL and HSS. Unless I'm missing something that's how I see it. Well notice how he states his real problem: I am wanting to start using fill flash during my outdoor portraits but my strobes won't sync at high shutter speeds when I shoot wide open. Nikon D850/D750
24Peter Senior Member 821 posts Likes: 1 Joined Nov 2005 Location: Dover, NJ More info | Dec 02, 2010 13:56 | #10 Eruditass wrote in post #11382705 HSS will use more power than using an ND filter by nature. ND filters will always be more efficient. Yes that is true with a Speedlite. Nikon D850/D750
Dec 02, 2010 14:00 | #11 Thanks for the feedback. I know about the ND filters. I have strobes and a speedlight. I didn't want to haul around the strobe + vegabond and buy an expensive ND filter for outdoor portraits. If I could use my speedlight for fill flash shooting wide open with an ETTL cord then that's what i'll do. Project Nine Five Photography
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Dec 02, 2010 14:04 | #12 24Peter wrote in post #11383403 Well notice how he states his real problem: I am wanting to start using fill flash during my outdoor portraits but my strobes won't sync at high shutter speeds when I shoot wide open. He wants fill flash while shooting wide open. He can either use HSS to get a higher shutter speed; or he can cut down on the amount of light using ND filters. Now he does imply he's already got strobes he can use (and presumably trigger) off camera. I use $30 ND filters without issue; my Canon OC-3 on the other hand was like $60 and it is only 3 ft long. The third party OC's I've tried never work as good (or in some cases at all) as the Canon. Oh, I understood the question and problem, and I also understand HSS and the use of ND filters. I use both methods. Robert
Dec 02, 2010 18:05 | #13 TMR Design wrote in post #11383482 The FlashZebra ETTL cord for Canon is as good if not better than the Canon cable. It's fairly long and priced quite reasonably. +1 on this, I have the long cord. Tim
JimM Goldmember 1,656 posts Likes: 39 Joined Aug 2006 More info | Dec 02, 2010 18:12 | #14 If you are using the flash for fill, I wouldn't think you would want the light to get too far from the camera. Long cord sounds like a winner to me.
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Dec 02, 2010 18:43 | #15 Jim M wrote in post #11385032 If you are using the flash for fill, I wouldn't think you would want the light to get too far from the camera. Long cord sounds like a winner to me. Exactly what I was thinking. For fill only, flash atop the camera should be fine. ...Leo
| Latest registered member is MWCarlsson 963 guests, 184 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
