Thread started 03 Dec 2010 (Friday) 07:22
Will CyberSyncs trigger Calumet/Bowens Travelite 750 strobes?
PixelMagic
Dec 03, 2010 07:22 |  #1
I currently own a few Radiopopper JrX Basic units and recently had a chance to use some Calumet/Bowens Travelite 750 strobes. Unfortunately the Radiopoppers wouldn't trigger the strobes; I've contacted RP and their suggestion was to change cables. :rolleyes:
This seems to be a fairly common problem based on what I've found online and no one seems to have a solution (something to do with polarity). See here for one discussion: http://www.flickr.com …iscuss/72157622​613785728/ (external link)
or here: http://www.fredmiranda​.com/forum/topic/82372​8/0 (external link)
or here: https://photography-on-the.net …hp?p=9051240&po​stcount=22
So now I'm looking at Cybersyncs...does the CSRB trigger Travelite strobes?
Thanks.
bobbyz
Dec 03, 2010 08:41 |  #2
Any trigger should be able to work as long as you have proper cable.
Fuji XT-1, 18-55mm
dmward
Gallery: 29 photos
Dec 03, 2010 09:04 |  #3
They should work.
There have been some discussions about polarity problems with certain trigger / light combinations.
Mine have always worked.
You might want to invest a couple dollars in a cable for the JrX that you can cut and reverse polarity just to see what happens.
PixelMagic
Dec 03, 2010 10:21 |  #4
bobbyz wrote in post #11387922 (external link)
Unfortunately its not as simple as that....if you read any of the links I posted you'd see its much more involved.
dmward wrote in post #11388009 (external link)
They should work.
I'll contact FlashZebra and see what they have but from what I've read around the 'net others have tried reversing polarity and it still didn't work. Perhaps I should just get some PocketWizard Plus II's and be done with it.
EmaginePixel
Dec 03, 2010 15:09 |  #5
I have the same strobes. And I use Cybersyncs.... they work great.
"Yesterday is history. Tomorrow is a mystery. Today is a gift. That’s why its called the present” - Kung Fu Panda
EmaginePixel.com website (external link) ----- SportsShooter profile (external link) ----- Facebook page (external link)
PixelMagic
Dec 03, 2010 15:42 |  #6
Awesome...thanks for confirming that Cybersyncs work with Travelite strobes.
mellofelow wrote in post #11389945 (external link)
PixelMagic
Dec 07, 2010 13:09 |  #7
Just an update in the event anyone else is looking for a solution:
I've been corresponding with both FlashZebra (Lon) and Kenyee and they have come up with workable solutions.
1. FlashZebra confirms that changing the sync cable works. He tested aFZ #0020 cord (external link) and it enables the Radiopopper to fire the Travelite strobe.
2. The second suggestion from Kenyee was to add a Wein Monoplug Safe-Sync (external link). This is a more expensive solution but I'm assured that it works.
3,116 views & 0 likes for this thread, 4 members have posted to it.
1064 guests, 104 members online
