| MIME changed to 'text/html' | Content warning: script |
A large CMOS sensor offers better image quality than a smaller because the larger may contain bigger-sized pixels. The relationship between image quality and pixel size can be readily understood if you imagine the pixel as a kind of bucket used to collect not water but light. This micron-sized bucket not only gathers light but also has a photodiode that stores an electrical charge.
Bigger pixels offer higher sensitivity
A regular bucket with a larger opening can collect more water in a shorter time than a smaller one. This is similar to the larger CMOS sensor compared to the smaller: the large one gathers more light in a shorter time and therefore can respond more sensitively.
Large-capacity pixels for wider dynamic range
Wide water buckets of greater depth hold more and have less spillover. In the same way, a larger pixel gathers more light with little or no waste. In CMOS sensors, minimal light overflow and greater capacity mean a wider dynamic range for more subtle gradations, especially in highlight areas. A CMOS sensor with extensive overflow will produce blowout. Smaller pixels are therefore more prone to blowout than larger ones.
Note: Dynamic range is a measure that indicates the scale of fine gradations being preserved from highlight to shadow.
Better S/N ratio from large-capacity pixels
Given two differently sized pixels handling the same amount of noise, there will be less noise impact on the resulting image of the larger pixel. Since larger-sized pixels catch more light, the signal carries more data than noise within the overall image information. This results in a better signal-to-noise ratio, which is particularly effective for fine gradation in low-light shots.
Note: S/N ratio is a measure indicating optical signal purity. The higher the S/N ratio, the smaller the amount of noise and, therefore, the signal may be described as one of high definition.
http://www.usa.canon.com …OS/technology-e/size.html
