Thread started 06 Dec 2010 (Monday) 02:18
If you have the option.....
Tareq
"I am very lazy, a normal consumer"
Dec 06, 2010 02:18 |  #1
.... how you will use it?
I shoot sports, football for about 3 years now, and i am happy so far to do, but i have an issue with sports results i get.
In the past i was using 1D2n with 70-200 2.8IS, later i got 300 2.8IS, and last i got 1DIII, i get the best result from 1D3 with 300, but now i am not sure if the result from my 1D2n as backup is on par, i don't like most results and i get a lot of OOF shots, so what you will do if you are in my place, use 300 with 1D2n and 1D3 with 70-200? I wish i can get another 1D3 or at least 1D4 but this is not possible now, how can i get the best out of my 70-200 then?
Galleries:
http://hamrani.deviant​art.com/gallery/ (external link)
Facebook (external link)
Mike ­ R
Dec 06, 2010 20:47 |  #2
I use my 70-200 F/2.8 (non IS) for most sports. My best results come from setting the camera for only 1 focus point and AI Servo.
Mike R
www.mikerubinphoto.com (external link)
malibubts
Dec 07, 2010 09:45 |  #3
Might also want to take a look at the Auto Expand C. Fn, 17 I believe. I was having trouble with some of my shots being slightly out of focus. My MK II was set to auto expand and after doing some research here I found that it was causing some OoF frames for people. Changing that setting helped a lot, might be something to look into.
Tareq
Dec 07, 2010 16:24 |  #4
Mike R wrote in post #11407233 (external link)
But i have 300mm, so no comparison here, also i set the camera to 1 center point and AI Servo and still not good shots.
Galleries:
Tareq
Dec 07, 2010 16:28 |  #5
malibubts wrote in post #11409979 (external link)
I am not sure i understand your points, but my C.Fn set at 0 which is Single AF point. I will test my 70-200 on MKIII and see if it will give me different better results, i remember that my 300 was very good on MKII, but i was hoping my 70-200 to perform great on my MKIIn as well, so will see what's wrong.
Galleries:
1,901 views & 0 likes for this thread, 3 members have posted to it.
1466 guests, 131 members online
