Thread started 06 Dec 2010 (Monday) 15:37
Peacock Herl
GJim
Dec 06, 2010 15:37 |  #1
Peacock herl is highly valued by fly-tiers for the natural iridescence.
This is a 10-shot stack. Canon 100mm Macro w/ Minolta 50mm reverse mounted, OCF, 1/250, f8, ISO 100, +2/3 FEC; shot tethered via lap-top - focus movement controlled via Live Remote Shooting - 1 'Medium Step' between each image. I have found that the lap-top needs to be on a separate table from the subject so as to eliminate vibration/movement.
G'Jim c):{- ... 2x 50D (Both Gripped), 2x 7D (Both Gripped), 2x 5D Mk II (One gripped), 1x 60D, assorted glass (10-800mm), sundry accoutrements.
The beginner clicks the shutter and says "Let's see what I got." ... The experienced photographer thinks "How can I capture what I see?"
My Photography: http://www.gjimphotogr​aphy.com (external link)
LordV
Dec 07, 2010 01:11 |  #2
Good interesting shot - not tried tethered shooting
Brian V.
Macro Hints and tips
janger
Dec 07, 2010 01:43 |  #3
GJim, any chance you could share the lighting setup for that shot? You seem to have avoided blowing out the metallic-like reflections pretty well. Or did you tone it down a bit in pp?
Dave
EOS 60D, EOS 500D, EF-S 18-55 IS, EF-S 55-250 IS, Sigma 120-400mm, Tamron 90mm, 430EX II, Yn-467 Flash
GJim
Dec 07, 2010 05:14 |  #4
janger wrote in post #11408543 (external link)
Dave:
Nothing special, really. Here is a fairly faithful re-construction of the shoot (sans subject and tether). I started by moving the back-drop (a piece of white construction paper supported by an empty Bourbon bottle) ;) to get initial focus, then used tethered focus for the 10 shots necessary for the stack.
I did do a fair amount of PP (in addition to stacking), but nothing that overly affected the 'metallic' appearance.
I'm also including one of the intermediate shots SOOC (just converted to jpg and re-sized for forum).
GJim
Dec 07, 2010 05:19 |  #5
LordV wrote in post #11408443 (external link)
Brian V.
With that particular lens setup, it's the only way that I can get accurate focusing. Attempting to hand-focus just doesn't work - too much vibration and difficult to obtain accurate, differential, steps.
LordV
Dec 07, 2010 05:40 |  #6
GJim wrote in post #11409072 (external link)
Not sure what mah you are using but if it's greater than around 2:1 then it's a lot easier to not use tripod but rest the camera on the same surface the subject is on- everything vibrated together then :)
Brian v.
GJim
Dec 07, 2010 07:03 |  #7
LordV wrote in post #11409118 (external link)
Brian v.
Brian:
That's a good idea - hadn't really thought about that. Will try that the next time I decide to shoot with that lens combo. Thanks!
Will still want to used tethered shooting, though - even the slightest bump would change shot line-up!
1,417 views & 0 likes for this thread, 3 members have posted to it.
Peacock Herl
1549 guests, 135 members online
