Thread started 06 Dec 2010 (Monday) 19:01
3 backpack reviews: Kata Bumblebee UL-222, Lowepro Primus AW, Dakine Sequence
David ­ Yi
Dec 06, 2010 19:01 |  #1
This is not a direct comparison between the bags as I have used only the Primus AW. However, these are my observations, measurements and impressions. Sorry for poor background / lighting; this was a quick shoot.
The rulers used are either 6" long or 18" long. I only have 1 camera, so it is a bit difficult to put my camera and gear in there to pose for photos.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/backpacks.jpg
Gear list: Canon 5D3, 24-105L, 100L macro, 70-200L 2.8 IS II, 580EXII; Gitzo GT1541T, Gitzo GM3551, Markins Q3T.
David ­ Yi
Dec 06, 2010 19:01 |  #2
Lowepro Primus AW. Paid $80 via Adorama @ Ebay.
Pros: nice colors, well padded. Weight is 4.5 lbs.
Cons: material is rough on skin, adjustable chest strap has a tendency to slide vertically, limited space for camera lenses, no dedicated notebook compartment though a 11.6" notebook will fit in the upper compartment, unable to find much use for outer exposed compartment (though it is fine for small jacket).
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/lp01.jpg
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/lp04.jpg
Main compartment has space for 1 camera with lens attached, 2 non attached lenses.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/lp06.jpg
This is the side compartment access. Honestly, I used it rarely as fit is tight even with non-gripped 7D.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/lp07.jpg
Here is the unprotected outer compartment. It is deep, but not much can fit much past 8 inches or so if it is thick.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/lp08.jpg
Bottom tripod holder
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/lp10.jpg
Top compartment. It is quite roomy...
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/lp11.jpg
Even a small notebook (Acer 18030T) or netbook should be able to fit.
David ­ Yi
Dec 06, 2010 19:11 as a reply to  @ David Yi's post |  #3
Kata Bumblebee UL-222.
Pros: ventilated mesh back works well - cool on back during limited testing, expensive (cost was $240, but $55 rebate is available currently). Weight is 5.4 lbs despite all of the goodies (weight trimming measures worked), good attention to small details, large and padded laptop compartment.
Cons: thinner material in non-camera area. Some zippers not that smooth when using them. Biggest bag of them all (which is a plus or minus). Waist strip is a bit too lightweight but is nicely ventilated.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/kb01.jpg
Backside.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/kb04.jpg
upper midline pocket.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/kb05.jpg
Top compartment.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/kb03.jpg
Lower midline pocket.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/kb06.jpg
Lower side pocket.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/kb07.jpg
Upper side pocket.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/kb08.jpg
All important camera compartment. Mesh covering.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/kb09.jpg
Left side mesh reinforced plastic covering has been unzipped.
David ­ Yi
Dec 06, 2010 19:12 |  #4
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/kb10.jpg
width of notebook compartment.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/kb11.jpg
Depth of notebook compartment.
David ­ Yi
Dec 06, 2010 19:22 as a reply to  @ David Yi's post |  #5
Dakine Sequence.
Pros: lots of pockets, inner bag may come in handy, heavy duty zippers. Price paid was $35 new (but it was on clearance! - very lucky deal on Black Friday)
Cons: heaviest of the 3 at 5.8 lbs, top compartment is barely usable. No good safe place to put even a small notebook computer without it getting in the way constantly.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds01.jpg
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds02.jpg
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds06.jpg
Top tripod holder.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds05.jpg
Bottom tripod holder.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/DS04.jpg
Main camera compartment.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds09.jpg
Backpack with camera bag removed.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds10.jpg
Camera bag only.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds11.jpg
Side pocket.
David ­ Yi
Dec 06, 2010 19:23 as a reply to  @ David Yi's post |  #6
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds15.jpg
Top compartment, very anterior depth.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds14.jpg
Top compartment, mid depth.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds13.jpg
Top compartment, posterior pocket depth.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds12.jpg
Rather tiny apex compartment. The handle and the top of the camera bag protrude into this space significantly. Not a good space for items that would be damaged if squished.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds03.jpg
I'm not sure what this strap is for. However, it can be very well hidden.
IMAGE: http://i1143.photobucket.com/albums/n638/david_yi/ds16.jpg
The only semi-accessible place for a notebook would be to close the camera bag with the inner cover, then place notebook on top. However, the notebook would only be lightly protected from the front of the backpack only. Not much cushion to the bottom (which is critical) or the sides.
David ­ Yi
Dec 06, 2010 19:41 as a reply to  @ David Yi's post |  #7
If you have any questions, please ask away. Otherwise, in the next week or so, I'll keep the Kata and sell the rest.
Main reason which I decided to keep the Kata:
* I REALLY hate having a sweaty back
* The Lowepro Primus AW fabric is very rough on skin, kind of like 400 grit sandpaper. The chest strap keeps moving around.
* The Dakine Sequence has no place for notebook. Very top compartment is too small for me.
* It has the same chest strap design as the Lowepro, so likely the chest strap will also be very likely to move around.
* The chest strap rubber shock absorber is way too weak to provide any help.
The one thing about the Kata that is useless is the "spine guard" and its associated pocket. I rather put a real piece of foam in that otherwise useless bowtie shaped pocket.
kingdavidd
Joined Jun 2010
Dec 07, 2010 09:36 |  #8
David Yi wrote in post #11406922 (external link)
Where did you purchase the kata with a rebate?
7D | EF 24-105L f4 | Sigma 10-20 f4-5.6 | Tamron 18-250 f3.5-6.3 | 270 EX | Slik Sprint Pro ii | Gitzo GT1541 with Manfrotto Head 496rc2
wish list: 70-200 f2.8 IS ii
azwizzard
Dec 07, 2010 11:05 |  #9
I bought a Lowepro Primus about 1 month ago. I used it for my carry on bag for my trip to Vegas.
So far I love this bag. I actually put my 11.6" Acer Netbook (in a neoprene sleeve) in the outer compartment. I put my sunglasses / jacket / and other stuff in the upper zippered compartment.
I did go to Walmart and bought a 3 pack of industrial strength Hook and Loop and added 2 more "compartments" for lenses in the lower section.
I haven't had any issues with the sternum strap moving on me... in fact, I find it really hard to move, so once I got it set in the right place, it is staying.
I am going to Disney Land later this month and will be taking this pack too.
I do really like the Kata Bumblebee, but don't really have the $$ to try it out right now.
Canon T1i, 18-55mm IS (Kit Lens), 55-250mm IS, EF 50mm 1.8, Lowepro Primus AW, Bagman Lg Shoulder Bag.
MR ­ do ­ little
Dec 07, 2010 12:22 |  #10
The Kata is much more expensive and in a different league imo. Similar priced bag from lowepro and Dakine will be more comparable.
I think the Kata is a excellent bag, but there are bags that are more durable and robust, which of course weigh more and are stiffer and boxier.
Regards
Paul L.
David ­ Yi
Dec 07, 2010 12:59 |  #11
kingdavidd wrote in post #11409938 (external link)
On Ebay. Kata has a rebate going on until 01/15/2011. $55 off. That brings the price from $240 - 55 (rebate) - 12 (Mr rebates) - 4.8 (ebay bucks) = about $168. Which is a very good price for bag of this caliber.
booja
Dec 07, 2010 19:33 |  #12
I'll take that dakine off your hands for the clearance price you bought it for 8)
10,129 views & 0 likes for this thread, 5 members have posted to it.
1044 guests, 168 members online
