Thread started 06 Dec 2010 (Monday) 23:05
Sorting .tif's from .cr2s with LR3 and Imagenomic
css7493
Dec 06, 2010 23:05 |  #1
I've been using Imagenomic Portraiture for quite some time, but recently I started processing large amounts once through it originating in LR3.
When it starts the process it creates a .tif of every image, they are also labeled 1 of 2, 2 of 2 for each photo (1 is the .tif, 2 is the .cr2). So when I do this, and it is all done, I have two of every image.
Heres the problem: I try and sort by every criteria I can to separate the .tifs from the .cr2s and they won't separate because they are 1 of 2, 2 of 2, etc.
How do I overcome this?
Gear
css7493
Dec 07, 2010 09:51 |  #2
ideas anyone? This is killing me :cry:
Gear
tonylong
...winded
Gallery: 60 photos
Dec 07, 2010 12:45 |  #3
What exactly are you trying to "sort out"? Lightroom lets you specify a "Sort Order" in your film strip, is that what you are looking for?
Tony
Zar9384
Dec 07, 2010 13:27 as a reply to  @ tonylong's post |  #4
I believe it may be stacking the images for you.
Right click one of those images and select Expand All Stacks. Then you can use the filters to display only .tif's or .cr2's.
Canon 20D
Asahi-Pentax MF Primes
ROSARIO EDWARDS PHOTOGRAPHY (external link)
css7493
Dec 07, 2010 18:48 as a reply to  @ Zar9384's post |  #5
Thats it, they were stacked
Thanks a ton!
I was almost resorting to more drastic measures, creating my images separately first before processing rather than letting portraiture/LR create them . . .
Thanks!
Gear
972 views & 0 likes for this thread, 3 members have posted to it.
Latest registered member is Sandro Bisotti
1751 guests, 169 members online
