litratista wrote in post #11409731
So if the PW is connected to the lightmeter, it will make a reading and automatically set the right stop for the flash output?
Ordinarily, the PW is not connected to the Sekonic light meter. There is a RFmodule that fits inside the meter to make it compatible with PW devices. However, if you don't have that module, then you can connect a regular PW transmitter to the meter via a short PC cable.
But either way, this allows you to trigger the lights with the light meter so you can take a meter reading. The meter will tell you what aperture you need to manually set the camera to to get the proper exposure from the strobes or flashes. You have to set the power output level on the strobes or flashes yourself; the meter won't do that for you.
Just as a side note, the meter does not have to have an RF module or be connected to a PW Tx device for it take light meter readings. You can trigger the strobes manually yourself to get the reading but it's more of a pain to do it this way than just triggering the strobes with the meter.
