guntoter wrote in post #11411336
Thank you for the advice. So a gaming computer also meets the specs. for Photo editing. Didn't know that.
Truth be told, this isn't really a gaming PC, but an editing PC in a gaming chassis. Gaming PCs need strong GPUs, which are often the most expensive part of the PC, while the GPU included here is ill-suited for gaming. It'd handle your needs just fine, but it won't be able to play Battlefield BC2 on high settings.
Editing PCs on the other hand have more RAM, stronger CPUs, and larger hard drives, which generally are cheaper than GPUs. Since photo editing programs are CPU intensive, they benefit much more from a strong CPU and don't really require a strong GPU to perform well.
So, essentially, what you have here is a pretty great media PC and a pretty bad gaming PC put in a fancy case with a good price. Lucky you!
