Thread started 08 Dec 2010 (Wednesday) 14:02
Microadjusting lenses - example
cristphoto
Dec 08, 2010 14:02 |  #1
I just got a Micro Lens Cal device which you use to make microadjusting your lenses a simple operation. To use it you simply ensure your camera and the MLC are on the same plane - I mounted each on tripods and leveled and checked height of lens and DLC. Then you simply follow the Canon owners manual on microadjustment - set center focus spot, single focus, lens wide open and make sure you're at least 50 times the focal length distance from the DLC (in this example I was using the 85L lens so I was about 15 feet away). I next took 3 photos each with 0 ma, -5, -10, +5 and +10. I then loaded all the photos into Lightroom to better view the results (my bodies don't have the latest hi-res screens). In my case the widest settings were -5 and +10 (typically I was hovering about +/- 5. You can vividly see where the best setting is for a given lens/body combo. In the attached photos the left is the 85L standard - no ma. The right is with only -5 ma. I tweaked the settings a bit thereafter but you can see the change. When using f1.2 just a hair off really shows. Besides the ruler, notice the text in the upper left corner. (The photos don't show this clearly but the top of the ruler is about 3 inches behind the target and the bottom is 3 inches in front, with 0 being on plane. Also my apologies for the crop size of the two photos not being equal, but you see the difference). I wasn't having any focus issues but I read an article about this device so I got myself an early Christmas gift. Well worth the $50 to make sure your equipment is working properly.
1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
themadman
Dec 08, 2010 14:04 |  #2
Holy chromatic aberrations!
Anyways, glad it works for you.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
Frugal
Dec 08, 2010 16:59 as a reply to  @ themadman's post |  #3
It looks like it's still back focusing...
Richard
Gear
ccp900
Dec 08, 2010 22:24 |  #4
why do the 85s have such bad CA.
[Sony A7R Mark 3 | Sony A7S | Sony Zeiss 16-35m f/4.0 | Sony FE 85m f1.8 | Sony FE 20m f1.8 G | Samyang 18m f2.8 | Samyang 45m f1.8 | Zeiss Batis 40m f2 | Sony FE 28m f2 | Sony Zeiss 55m f1.8 | Sony FE 28-70m f/3.5-5.6 | Helios 44-2 | Helios 44-3 | Nikon 105m f/2.5 AIS | Contax Zeiss Planar 50m f1.7 | Contax Zeiss Planar 100m f2 | Voigtlander Nokton 40m f/1.4 | Canon 24-105m f/4.0L | Canon 85m f/1.8 | Sigma 30m f/1.4 | Canon 10-22m f/3.5-4.5 | Canon 100m f/2.8 Macro USM | Canon 580 EX Ver 1.0]
tim
Light Bringer
Dec 08, 2010 22:44 |  #5
Try it at both minimum and maximum zoom (not with the prime obviously but in general), and both close to the target and distant. You'll probably find there's no one MA value that works for everything. Canon lenses generally need calibration to get the lens right at all zoom/distance combinations, even then it can take Canon a few tried to get it working properly.
newworld666
Dec 09, 2010 07:01 |  #6
:rolleyes: I am still wondering how you can align correctly with such target :confused: ..
Lensalign pro has got holes with 10cm deep red pins to get a perfect alignment. Actually, I wouldn't trust your results without being sure your sensor is at exactly parallel from the target.
Marc
5DMKII+1Dx 24L1.4II 85L1.2II 180L3.5 300F2.8nonIS TC2XII ..... Sigma14F2.8AFDG, Zuiko 500F/8 Reflex
http://myc-photos.eu (external link)
richwood
Dec 09, 2010 07:24 |  #7
newworld666 wrote in post #11421589 (external link)
The target you focus on is right next to the measurement point. Unless you've got the calibration device almost perpendicular to the camera, it's not going to be off by more than a fraction of a mm, and certainly well within the depth of field of any lens you're likely to be working with.
My toys
newworld666
Dec 09, 2010 07:51 |  #8
Actually there is clearly "a type" of back focusing, but I wouldn't trust it, till I am not sure the sensor is parallel to the target.
Marc
cristphoto
Dec 09, 2010 14:13 |  #9
Frugal wrote in post #11418707 (external link)
That's been dialed out (-3ma). Per the Canon owners manual they say adjust in large steps (I was using increments of 5). It was amazing how in just an adjustment of 5 units could take the ruler from fully blurred to pretty sharp. I got my lenses so the ruler was clear typically from +2 to -2. No single adjustment would give just a clear 0 and all else blurred. Each numbered increment is less than an inch so even at 1.2 you still have a couple inches of DOF (you aren't supposed to calibrate at the minimum focus distance - depending on my lens I was shooting at between 6 feet and 60 feet). Also when using this device you are shooting at the distance where the center focus spot aligns with the large black/white square. When looking though the viewfinder the focus spot will cover a good part of that area. I then assure that I'm square and level to the device but in actual use you don't have to split hairs - just set-up fairly resonable and shoot. Surprisingly in my case the "infamous" 50L took the least amount of adjustment (0 on one body and 3 on the other) where the 135 took the most (8 and 10 ma) on the two bodies. But as I said in my original post I wasn't having any issues, but simply wanted to confirm all was working within limits (particularly while some equipment is still under warranty). All in all a helpful tool if you have the ability to micro-adjust your camera/lens combinations.
3,035 views & 0 likes for this thread, 7 members have posted to it.
1154 guests, 136 members online
