After attempting to understand the connections for graphics cards and monitors, I've got a few questions and am looking for input/insight and maybe some good old technical descriptions from those in the know.
The graphics card in my system (EVGA GeForce GTS 450 1 GB; http://www.evga.com/products/pdf/01G-P3-1450.pdf
) has two Dual-Link DVI-I ports and a mini-HDMI 1.4a port. The monitor I'm interested in has specs of 2xDVI-D and 1xDisplayPort (NEC multisync PA271W-BK-SV; http://www.necdisplay.com …70-4c6a-a511-6d39c54f61bd
). The monitor comes with a DVI-D to DVI-D (dual link DVI) cable according to the online User Manual.
If the Dual-link DVI-I and DVI-D (Dual-link?) ports are different (and they are, right?), are they still compatible? Will the provided cable connect them? My system builder told me that the DVI to DVI commonality would provide the connection compatibility but I'm still unsure why that is if one is DVI-I and the other is DVI-D. I think I understand that the dual-link feature allows for the maximum resolution capability of the monitor at 2560 x 1440. I'm sure there is a technical explanation that has eluded me about DVI-I vs DVI-D.
I've seen drawings of the cable ends/ports for each the dual-link DVI-I and dual-link DVI-D and they do look different. I've read a few articles and am spinning my wheels.
Some of the other NEC monitors offer DVI-I, VGA, DVI-D (HDCP), and the DisplayPort. I would like to get a better understanding of what each is best for as far as intended use, and compatibility with graphics cards' ports.
Also, what is a mini-HDMI 1.4a port use for?
If you can provide the answer, some input, or point me to other resources or links for this topic, I would be much obliged. Nancy
