Thread started 09 Dec 2010 (Thursday) 13:13
Canon FD 20mm f3.5 macrophoto lens
Blackdeath
Dec 09, 2010 13:13 |  #1
I like to re-cycle old gear as much as possible. Macro gives a great opportunity to use old FD macro lenses on bellows or extension tubes. You get the advantage of the using some classic glass at a bargain price and you never have to worry about infinity focussing, so a glassless EOS/FD converter will do the trick.
I already have the FD 50mm, 100mm and 200mm macro lenses together with both FL and FD auto bellows. Now I am awaiting the arrival of a 20mm f3.5 Canon macrophoto lens. This was made specifically for use on bellows, and will give reproduction rations of between 2.2:1 and 10.7:1 using extensions between 5mm and 175mm.
This sounds like fun! The question is, does anybody have any experience or sample shots taken with either this lens or its companion the FD 35mm f2.8 macrophoto?
Details on the lens are here:
http://www.mir.com.my …ses/fdmacro/203​5macro.htm (external link)
Paul
60D, 40D Infra-red
Martin ­ G.
Dec 09, 2010 15:58 |  #2
hopefully you do not mind me adding a question here
interesting lenses, thank you for sharing, anyone knows if this lens performs as good as a microscope objective at 10x? Would IQ comparable to a MPE? Might be nice to complete the MPE between 5:1 and 10:1?
6D & 70D
EF 24-105 L, EF 40mm, EF 85mm f1.8, EF 100mm L IS, MP-E 65
Macro Twin Flash MT-24EX, 430 EX II & 270 EX
realjax
Dec 10, 2010 03:35 |  #3
Although I do not own this lens (unfortunately, because it's a nice objective!), I can assure you that a fairly cheap microscope objective will outperform it at the magnification it was designed for (5x or 10x for example) . Having said that, the canon is far more versatile since,
a) it has a variable aperture,
b) probably a more comfortable working distance and
c) a more consistent performance on various magnifications.
I suspect the Canon will perform best at around 5x.
If given a choice I'd prefer the 35mm version for it's 6 element design as opposed to the 4 elements of the 20mm.
Still I'm envious. :)
Jacco
LLBNY
Dec 10, 2010 14:04 as a reply to  @ realjax's post |  #4
First, I need to say that I bought the 2 lenses in the 80’s, may be before as I just got them when they came out.
I used them with film on a Minolta at that time, and they were since in a box. I just took them out of the box a month ago to do one set of stack for test.
So this is the second time they are used since and I am testing on how to do stacks. Since I am not a ‘stack’ specialist, anything can go wrong and defects may not be due to the Canon lens quality or lack of it.
This is made with the 20mm using my not finished studio setup. I posted one picture a week ago and Jax gave me some very useful info to correct some problems I have.
There are 2 tests. Nothing was done to the picture and they are as they came from the camera .
The 2 first pictures are made with the 20mm with a total lenth of 158mm between the ‘film’ plane and the tip of the lens. Aperture 5.6, 100ISA. Full ETTL on the MT24X
Stack of 52 pictures in demo ZS- the width you see is 4mm
One shot
The second set is made with the same setup but with 310mm instead of 158mm. I tried to do it quick on my dining room table so it looks like there is some vibrations, but it could be something else. I just do not know at this point.
Stack of 55+ pictures in demo ZS- the width is about 2mm
IMAGE: http://farm6.static.flickr.com/5090/5249811880_9741eea0e1_o.jpg
One shot
IMAGE: http://farm6.static.flickr.com/5003/5249907768_c7d2b1f97f_o.jpg
I just received the Nikon Plan B 10x, but I cannot use it yet since I didn’t receive the cone adaptor to mount it on the bellows.
Since I also have the Canon macrophoto 35mm , I will try to do some tests soon.
I do not know the mag. for this shots, so if someone can help?:oops:
http://www.flickr.com/​photos/bugslou/collect​ions/ (external link)
Martin ­ G.
Dec 10, 2010 14:51 as a reply to  @ LLBNY's post |  #5
Realjax,
Thank you for your input, since I already have the MPE, I think the 20mm would be more interesting for me (seems like the 35 mm will go up to 5:1 or so only).
Even with less IQ, I think this could be more suitable for me, as I prefer to fiddle on the field then with elaborate micro focussing rails and all the complicated set ups that I see on the microphotography forum.
LLBNY,
thanks for posting images, would certainly be interested to see some more in the future.
Do you recall how much you paid at the time for the 20mm? Just curious, just found a few on ebay and they are quite pricy, over 300$... not sure if it is worth that much, specially that i am not sure if I will like it or not. What do you guys think?
When you bought it, was there some kind of booklet or instruction manual that said how much mag vs. extension? Would be interesting to have.
If anyone else has any images or links, would be nice to see more samples.
Thank you everyone for your participation
Martin
6D & 70D
LLBNY
Dec 10, 2010 15:05 |  #6
I may have an invoice from that time, but where?. I really doubt that they cost at that time as much as what they want on Ebay (399 I believe), but I do not remember.
Somebody asked me if it is worth it, I must say it is worth it for me because I have them. Will I by them for over $600, i do not think I would..
Booklet: I do not have the booklet anymore, so I do not know.
Blackdeath
Dec 10, 2010 16:26 as a reply to  @ LLBNY's post |  #7
Prices and instruction sheets
Thank you all for you brilliant input and especially for those stunning photos. I can't wait for my parcel to arrive!
From my 1986 price list, the macrophoto stuff was as follows:
20mm f3.5 $139.50
35mm f2.8 $168.50
There was no price given for the Macrophoto lens adaptor, which was supplied separately.
The instruction sheet for the lenses can be found at http://web.archive.org …nses/macrophoto​lenses.pdf (external link)
Paul
60D, 40D Infra-red
realjax
Dec 10, 2010 16:27 |  #8
Martin G. wrote in post #11429723 (external link)
Martin, If I'm not mistaken there are some tables with just this info in the manual for the Canon Auto bellows. The FD version. That manual can also be found online as a pdf somewhere. If you can't find it just let me know. Keep in mind that those tables are based on 35mm camera's though. On crops it's a different story.
LLBNY wrote in post #11429466 (external link)
[I do not know the mag. for this shots, so if someone can help?:oops:
for instance the 2mm wide shot on the 50d means about a 11x magnification.
sensor = 22.3mm, image = 2 mm -> 22.3/2 = 11.1
Jacco
LLBNY
Dec 10, 2010 17:16 |  #9
Thanks.
Actually I was looking for a formula where I could input the focal, the distance between the lens and the film plan. and the sensor size.
Anyone?
Martin ­ G.
Dec 10, 2010 17:17 |  #10
thank you everyone
Realjax, I found the manual and the charts, ( http://www.joe-chan.com/manuals (external link) ) but they do not include unfortunately the 20 mm in there, I will keep searching.
Martin
6D & 70D
Blackdeath
Dec 10, 2010 17:52 as a reply to  @ Martin G.'s post |  #11
Martin, thanks for that, but save yourself the effort of looking further, because the tables are given in the instruction book for the lenses. The web address for that is given in my previous post, further up the page.
Even more useful instruction books are available from the links given here: http://web.archive.org …ww.canonfd.com/​choose.htm (external link) :D
Paul
60D, 40D Infra-red
Martin ­ G.
Dec 10, 2010 18:03 |  #12
Paul, excellent, thank you for that... all there and much helpful!
6D & 70D
LLBNY
Dec 10, 2010 18:24 |  #13
Tx PAul, Excellent and priceless info.
realjax
Dec 13, 2010 09:57 |  #14
LLBNY wrote in post #11430444 (external link)
Thanks.
Anyone?
Well I know of this one, but it's not as acurate as simply using a shot from a ruler :)
magnification = em + (ex / fl)
where
em = existing magnification ( in other words, with no extension whatsoever)
ex = total extension ( *not* same as distance between the lens and the film plan)
fl = focal length of lens.
Jacco
LLBNY
Dec 13, 2010 11:31 as a reply to  @ realjax's post |  #15
Well I found a formula - with a lot more parameters!
At the end I made a small test with a small steel ruler i have, but I need to find one with smaller lines and better resolution. In any case my spreadsheet is ready.
Will see after my european vacations now:).
13,234 views & 0 likes for this thread, 6 members have posted to it.
1078 guests, 175 members online
