Thread started 09 Dec 2010 (Thursday) 16:26
A question to owners of Pro Canon Cameras or Recent Canon Cameras
yb98
Joined Feb 2003
Dec 09, 2010 16:26 |  #1
When you open a raw file in DPP, do you see the same RAW Histogram as in the following pic ? I mean do you have 2 gray columns in each side and do they have the same size as in the pic below ? or is the white surface wider ? Thanks.
Digital Rebel
Best DPP Threads
DPP++ Video Channel (external link)
New Version DPP++ 11.3 released (external link)
tonylong
...winded
Gallery: 60 photos
Dec 09, 2010 17:22 |  #2
Well, my 5D Classic and 1D3 both have the gray stripes, although on both the left edge of the right stipe, where the white point line starts (by default) is a bit more to the right.
I don't know what the purpose/function of those gray zones is -- I can't find a way of getting them to budge and you can't evidently drag the white or black point lines into the gray zones. Tried switching to Linear and it didn't change things either.
But I only have Raw files from those two and nothing from a newer body.
So, I plead ignorance:)!
Tony
ncjohn
Dec 09, 2010 20:33 as a reply to  @ tonylong's post |  #3
The white area is about the same width but placed differently. The left edge of the white is at exactly -8.0 and the right edge of the white is even with the right edge of the 0 in "4.0".
I checked with several different photos and they were all the same. I have a 450D that's about 8 months old.
tonylong
...winded
Gallery: 60 photos
Dec 09, 2010 20:44 |  #4
Hmm, interesting -- it soulds like there is slight variations between all three -- I wonder if it's camera related, or just a bit of a difference between software, systems, displays...?
Tony
yb98
Joined Feb 2003
Dec 09, 2010 20:51 |  #5
I think it's camera related. Each sensor has it's own dynamic range. The wider white surface, the higher dynamic range.
It seems that the 450D can get more information in brighter situations and less information in darker ones.
Best DPP Threads
ncjohn
Dec 09, 2010 20:55 |  #6
tonylong wrote in post #11425782 (external link)
Based on my extensive, long-term experience and knowledge of how all these things work, I feel pretty sure that I don't have a clue!:)
bohdank
Dec 09, 2010 21:17 |  #7
I have no idea what it means but my 5DII shows the upper end, almost at the -4 mark and about the same as the OP's at the other end. The 5D looks the same. The 40D is a bit lower at the top end compared to the 5D/5DII. The 7D is similar to the 5DII/5D.
jetcode
Dec 09, 2010 21:25 |  #8
bannedPermanently
The white represents the signal range from black to white in the native A/D converter (raw data) resolution. The gray represent hard stops or areas that are invalid. Signals close to white have higher resolution (more steps per zone, Ansel Adams zone system) than signals close to black.
yb98
Joined Feb 2003
Dec 09, 2010 21:30 |  #9
bohdank wrote in post #11425963 (external link)
Could you please post the 40D and the 7D histograms in this thread ? : https://photography-on-the.net/forum/showthre​ad.php?t=969927
Best DPP Threads
bohdank
Dec 09, 2010 21:43 |  #10
Done. I also added the 5DII.
yb98
Joined Feb 2003
Dec 09, 2010 21:45 |  #11
bohdank wrote in post #11426084 (external link)
Done.
Thanks !
Best DPP Threads
tonylong
...winded
Gallery: 60 photos
Dec 09, 2010 23:17 |  #12
I loaded my histogram to the new thread...
Heh! I had a hilarious time accomplishing that simple task, though -- simple, as long as I can look back and chuckle at my trials and adversities:)!
I've been working with my little laptop, which does have DPP but doesn't have Lightroom or Photoshop, it does not have an editor I'm familiar with -- Paint has been "remodeled" for Win7 (maybe Vista) and doesn't have the old familiar Windows menus, just toolbars that seem to change around willy-nilly...
And, a while back the battery-powered wireless mouse I had been using died, so I decided to make myself get used to using the fingerpad, which I hate because it always does crazy stuff I don't want, but I've been toughing it out, not changing any settings and only disabling it when I'm typing out something and I can't afford it going crazy on me (learned by experience).
So, bumbling through getting my screenshot open in Paint, cropped and sized and saved, and then using the Attach function here, all with the finger pad doing its usual crazy stuff...hilarious...
Tony
tzalman
Fatal attraction.
Dec 10, 2010 01:34 |  #13
It might be of interest to note that when Highlight Tone Priority is enabled the histogram shifts approximately one stop to the right. Attached is from a 5D2. The 40D shows the same shift.
Elie / אלי
yb98
Joined Feb 2003
Dec 10, 2010 01:39 |  #14
tonylong wrote in post #11426516 (external link)
Thanks for the effort !
Best DPP Threads
jetcode
Dec 10, 2010 10:27 |  #15
bannedPermanently
tzalman wrote in post #11426881 (external link)
The gray zone then is a graph buffer (and hard stop) and the white zone represents actual potential resolution and distribution of data. One graph many cameras hence the shifts.
3,796 views & 0 likes for this thread, 6 members have posted to it.
1582 guests, 138 members online
