Can someone explain to me what the depth of field button does and how or why I would need to use it? Thank you.
Dec 09, 2010 16:45 | #1 Can someone explain to me what the depth of field button does and how or why I would need to use it? Thank you.
nepali Senior Member 986 posts Likes: 4 Joined Sep 2010 Location: Dallas, TX More info | Dec 09, 2010 16:46 | #2 RonA18 wrote in post #11424709 Can someone explain to me what the depth of field button does and how or why I would need to use it? Thank you. I could explain but I am too lazy!
RTPVid Goldmember 3,365 posts Likes: 3 Joined Aug 2010 Location: MN More info | Dec 09, 2010 16:47 | #3 It stops the lens down to the taking aperture so you can see an approximation of the DOF through the viewfinder. Tom
Snydremark my very own Lightrules moment More info | Dec 09, 2010 16:51 | #4 When you focus your camera, or AF is focusing for you, the lens is always open to its maximum aperture, so you don't see the final depth of field from your photo through the viewfinder. - Eric S.: My Birds/Wildlife
themadman Cream of the Crop 18,871 posts Likes: 14 Joined Nov 2009 Location: Northern California More info | Dec 09, 2010 16:55 | #5 It just stops the lens down to whatever your setting is. Normally the lens is wide open and only stops down when you take the photo. Will | WilliamLiuPhotography.com
Invertalon Cream of the Crop 6,495 posts Likes: 24 Joined Jun 2009 Location: Cleveland, OH More info | Dec 09, 2010 16:58 | #6 |
msowsun "approx 8mm" More info | Dec 09, 2010 17:03 | #7 Invertalon wrote in post #11424783 This always confused me... All it does it darken the edges of my viewfinder when I used it, and honestly made little to no sense for me. Oh well, its AF Servo - One Shot button now ![]() You aren't looking the darkened image carefully enough. It does more than just darken. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
TheBurningCrown Goldmember 4,882 posts Likes: 3 Joined Oct 2008 More info | Dec 09, 2010 17:09 | #8 msowsun wrote in post #11424801 You aren't looking the darkened image carefully enough. It does more than just darken. It gives you a preview of the depth of field -Dave
xhack Goldmember 1,283 posts Likes: 2 Joined Jul 2007 Location: Edinburgh, Lothian More info | Dec 09, 2010 17:19 | #9 It made great sense back in the days of film, when viewfinders seemed - subjectively - much brighter. Even on my 5D which does have a bright VF image for a DSLR, I find the DoF button of limited use ~ Wallace
MikeFairbanks Cream of the Crop 6,428 posts Likes: 2 Joined Jun 2009 More info | Dec 09, 2010 17:24 | #10 I've tried it and it didn't work. In fact, the last time I pressed the button I got a scrolling advertisement at the bottom for Extenze. Thank you.
Mark_48 Goldmember 2,068 posts Joined Nov 2004 Location: Brookfield, MA More info | I don't use the DOF button much, but the DOH button gets hit accidently once in a while Megapixels and high ISO are a digital photographers heroin. Once you have a little, you just want more and more. It doesn't stop until your bank account is run dry.
BillBoehme Enjoy being spanked More info | DOF preview is most useful when using a long telephoto lens since the DOF is so shallow, BUT when using a long telephoto, I almost always shoot wide open so that I can use a fast shutter speed and low ISO which means that DOF preview and the normal wide open view are the same. Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Dec 09, 2010 18:30 | #13 Thanks all for the great info and for the comedy as well. I just picked up the 100mm Macro and will see how this feature helps.
Russ61 Senior Member 265 posts Likes: 2 Joined Aug 2009 Location: Tacoma, WA area More info | Dec 09, 2010 20:04 | #14 Others mentioned that your preview is at your lens' max aperture and thus DOF. Pressing the preview button instantly stops the lens down to the preset aperture. If that aperture is 1 stop smaller you'll see very little difference in darkness or DOF. If its f-16 or smaller you'll see a MUCH darker viewfinder and a distinct difference in DOF....once your eyes get acclimated to the difference in light. A trick is (in manual aperture) click the preview button and then spin the aperture control to increment from widest to desire smaller aperture, coincidentally incrementally acclimatizing your eyes to the diminishing brightness. Once you get conditioned/trained to assess DOF in dimmer light, this can be a very handy feature. I just would like a camera with a more readily/intuitively accessible DOF preview button as I'm always fumbling around the front trying to find mine.
Dec 09, 2010 20:12 | #15 Great tip. I'll have to check it out.
| Latest registered member is Niagara Wedding Photographer 1321 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
