Thread started 10 Dec 2010 (Friday) 20:57
ACR open in LR3
canon ­ shooter
Dec 10, 2010 20:57 |  #1
Daughter processed some images in CS5 through ACR and now when the RAW images are opened in LR looks like some to the adjustments made in ACR are showing in LR.
Is this normal (since they are the same engine)? Or did she some how make changes to the RAW images?
Jim
5D Mark III Grip, 40D Grip, Canon 17-40L, Canon 24-105 F4L IS, Canon 70-200 IS II F2.8L, Canon 100-400L, Canon 50 F1.4, Canon 100 F2.8, Canon 580 EX
It's the Glass that Counts!
tonylong
...winded
Gallery: 60 photos
Dec 11, 2010 01:23 |  #2
If LR is set up to read metadata from "sidecar" xmp files then ACR adjustments will show up.
To go back to original settings, just click the Reset button in the Develop module, or you can go through the History panel on the left side of the Develop module.
But, if you want to keep the things your daughter did intact while you work in Lightroom, you will want to first go to your Preferences and turn off the automatic reading from and writing to metadata to files.
Tony
canon ­ shooter
Dec 11, 2010 08:57 |  #3
tonylong wrote in post #11432206 (external link)
So you are saying even if you thought you only imported the CR2 files (RAW) we still got the sidecar files.
Assume ACR is like LR and the adjustments made in ACR are not made to the RAW file?
Jim
René ­ Damkot
Dec 11, 2010 12:59 |  #4
canon shooter wrote in post #11433144 (external link)
LR / ACR will always read a sidecar file if it's there on import / opening of the raw file.
If a sidecar file is added after LR imported the files, LR will ignore it, unless it's told to read it.
Yes.
Edits are stored in a sidecar file (ACR) or a sidecar file or the catalog, depending on prefs (LR)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
710 views & 0 likes for this thread, 3 members have posted to it.
ACR open in LR3
2571 guests, 152 members online
