Gonna buy one but can't tell which is better
L.Morey Goldmember 1,571 posts Joined Oct 2005 Location: Modesto Ca More info | Dec 11, 2010 13:00 | #1 Gonna buy one but can't tell which is better 7d gripped,40d gripped,G9,17-40f4L, 24-70f2.8 L, 70-200f2.8 mkll L, 100-400 f4.5-5.6 L, 50f1.4 , 85f1.8 , Sigma 24-70f2.8
A.Rivera Member 83 posts Likes: 1 Joined Dec 2010 More info | Dec 11, 2010 14:30 | #2 I dont own either one, but I went to a local camera shop yesterday to compare them. They are both great from what I can see. However since I will be doing more street traveling with mine, I like the 190cx, its a little smaller and lighter.
sempaidavid Senior Member 890 posts Joined Nov 2006 Location: Fresno CA More info | Dec 11, 2010 15:18 | #3 I own both. The 055 is big and heavy and great for studio work. It is also quite tall. The 190 is much smaller and lighter. It is what I take out hiking. Also, I am short- 5'6" and it is the perfect height without extending the center shaft at all. 5D mkIII, 1D mkIV, Tokina 16-28 f/2.8, EF 24-70L, EF 70-200 f/2.8L II IS, EF 100-400L, EF 85 f/1.8, Sigma 50 f/1.4, EF 24-105
MCAsan Goldmember 3,918 posts Likes: 88 Joined Jun 2010 Location: Atlanta More info | We have had the 055proB tripods. It is a bit tall for the wife...and the 190 would be too short for me. Did not like the stability of the 190. Also found I do not use a center column. So for Christmas we are replacing those with carbon tripods.
Snydremark my very own Lightrules moment More info | Both good, one's larger/heavier/sturdier (055) and one's smaller/lighter/more compact (190). I own the 055 in both the aluminum and carbon fiber (4 section) variants; I just recently upgraded to the CF model because the aluminum one is simply too large and heavy to carry around regularly. - Eric S.: My Birds/Wildlife
kingdaddy Senior Member 396 posts Likes: 1 Joined Feb 2009 Location: Fort Worth More info | Dec 11, 2010 20:20 | #6 I have had my 190 CX Por3 in one hand while holding the 055 in the other and can tell you that if you are going to carry one on a hike there is no comparison which one I would pick, the 055 is much heaver and will go taller but is almost the same size collapsed. However the 190 is as stable as I would need with a pro body gripped and a medium lens doing video in a strong wind, which Ive done. 6D | 7D | XSI | EF-S 10-22 | EF 50 1.4 | EF 24-105L | 100-400L │ EF-100mm Macro| MT-24EX │580 EXII | Black Rapid RS-5 | lots of Think Tank.
| Latest registered member is semonsters 1027 guests, 106 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
