I have heard from different people that when you frame with glass you should never use a gloss paper because of increased reflections and that only a luster or matt should be used?
Any insight on this is appreciated
Cheers Mark.
picworx Goldmember 1,147 posts Likes: 4 Joined Jun 2005 Location: Ontario, Canada More info | Dec 11, 2010 13:39 | #1 I have heard from different people that when you frame with glass you should never use a gloss paper because of increased reflections and that only a luster or matt should be used?
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | Dec 12, 2010 09:49 | #2 Not true. And framing gloss under glass helps reduce any metamerism or bronzing issues your printer/paper combination may suffer from. Chas P
Dec 12, 2010 09:55 | #3 Thnx, ChasP505
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Dec 12, 2010 10:16 | #4 Framing a glossy print under glass, may -- if the print is in direct contact with the glass, rather than separated from it by a matte surround -- result in the phenomenon known as Newton Rings, which is a rainbow like interference pattern. That is why one can buy anti-Newton glass, which has a subtle textured surface on the side facing the print. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
navydoc Cream of the Crop More info | If you're concerned about reflections, you can get Museum glass Gene - My Photo Gallery ||
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | A properly matted and framed photo will have a small gap between the print and the glass so the glass isn't in contact with the print. And always give at least a week for the print to fully dry before framing. Chas P
rw2 Goldmember 4,201 posts Likes: 3 Joined Jun 2006 Location: North Dakota More info | Dec 12, 2010 14:12 | #7 I use non-glare glass. It is better than regular glass and is not overly pricey. If you're afraid of failure ... you'll never succeed!
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | Dec 12, 2010 14:19 | #8 rw2 wrote in post #11439452 I use non-glare glass. It is better than regular glass and is not overly pricey. Depending on the context - for framed prints that I am selling, I used non-glare museum glass for the benefit of the customer. .
ChasP505 "brain damaged old guy" 5,566 posts Likes: 1 Joined Dec 2006 Location: New Mexico, USA More info | Dec 12, 2010 15:13 | #9 Radtech1 wrote in post #11439483 See, when you look at a framed print, most reflections will seem to disappear from the viewer's awareness, BUT when someone takes a picture of my print, then the reflection is all they get. Rad Nice... Chas P
agedbriar Goldmember 2,657 posts Likes: 399 Joined Jan 2007 Location: Slovenia More info | Dec 13, 2010 09:14 | #10 navydoc wrote in post #11438400 If you're concerned about reflections, you can get Museum glass My son had a set of frames made with museum glass. Very expensive and I was not impressed at all.
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Dec 13, 2010 10:59 | #11 It's a personal preference.... I make matte prints for the crisper detail they offer, then frame them under standard picture glass, which is not "non glare" glass. Alan Myers
RDKirk Adorama says I'm "packed." More info | Dec 13, 2010 11:41 | #12 picworx wrote in post #11434359 I have heard from different people that when you frame with glass you should never use a gloss paper because of increased reflections and that only a luster or matt should be used? Any insight on this is appreciated. If you use ordinary glazing (picture glass or acrylic) there will be reflections, but it will be the same reflections as on the glossy print. So whatever angle control you can use at the display location (or whatever position the viewers have to take to view it without reflection) will work for both coincidentally. TANSTAAFL--The Only Unbreakable Rule in Photography
| Latest registered member was a spammer, and banned as such! 2585 guests, 153 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
