Thread started 12 Dec 2010 (Sunday) 07:39
Mental checklist - Tips and Tricks?
Roroco
Dec 12, 2010 07:39 |  #1
OK... As I move more into the realm of shooting mostly everything in manual, I find myself every so often forgetting a step and missing a few shots. I'll move from inside to outside and forget to change the ISO, or I put a remote trigger on my flash and forget to change it to manual and the proper exposure.
With so much to remember, do you guys have any tips or tricks to remember what has to be done with each shot? When you are shooting, what step do you do to insure you are making the proper adjustments each time to change scenes?
Thanks guys.
Roger
Gear List: 5D Mark III -- 50mm f/1.4 -- 85mm f1.8 -- 100mm f/2.8L IS Macro -- 17-40mm f/4L -- Tamron 24-70mm f/2.8 VC -- 70-200mm f/2.8L IS II -- 2.0X III TC
Lights -- Alien Bees B800 -- 580 EX II -- Yongnuo YN-560 II & YN-568EX -- Mother Nature -- RF 602s
mikekelley
"Meow! Bark! Honk! Hiss! Grrr! Tweet!"
Dec 12, 2010 09:44 |  #2
You just need to get into a routine. Do the same thing every time. Make it mnemonic if you need to.
The more you do it, the easier it gets. In a month, you'll be good to go if you just keep forcing yourself to get out there and adjust on the fly.
Los Angeles-Based Architectural, Interior, And Luxury Real Estate Photography (external link)
How To Photograph Real Estate and Architecture (external link)
My Fine Art Galleries (external link)
My articles at Fstoppers.com (external link)
birdfromboat
Location: somewhere in Oregon trying to keep this laptop dry
Dec 12, 2010 10:15 |  #3
In my job I have many tasks that require attention to details and mental checklists. We all deal with it in our own way, but I think all the apprentices I have trained and myself and the guy that trained me arrived at some method of "starting point" thinking. There is a thought process that gets you to a point where you can devote your energy to being sure it is right. Tie up the loose ends of whatever was happening before, finish any conversations, put away any loose tools, and then begin to do the task. It gets easier to do after you do it about a gazillion times, the next big trick is learning to distrust yourself- being aware of and willing to stop everything and check up on your own ability to forget something and screw it up.
5D, 10D, G10, the required 100 macro, 24-70, 70-200 f/2.8, 300 f2.8)
Looking through a glass un-yun
bdp23
Dec 12, 2010 10:36 |  #4
I'm pretty sure there's only one thing that matters when in Manual mode:
Look at the meter.
You say you forget to change the ISO when you walk inside? Then the meter will probably be way off to the left.
Metering for full manual flash control is explained here: (1/3 the way down) http://photonotes.org …les/eos-flash/index3.html (external link)
I like making photos and sometimes I think I'm getting better... then I realise it doesn't matter. I like making photos!
1,271 views & 0 likes for this thread
Latest registered member is Ezra Praveen
895 guests, 294 members online
