Thread started 12 Dec 2010 (Sunday) 14:16
Need some help with CS5/bridge
robonrome
Dec 12, 2010 14:16 |  #1
Hi - i recently went from PC to apple and upgraded from CS4 to CS5 at the same time. Mostly fine but I have a couple of annoying problems I just haven't been able to work out - be grateful for any help:D
1) Great to have lens distortion now in the RAW converter, but once opened in PS I can now no longer access this facility under Distort in the Filter menu. There is the Lens Correction facility but it's hardly the same thing. ANy idea where this function is hiding? EDIT DoH..just found what I was looking for here under the Custom Tab in Lens Correction
2) In Bridge i usually click on the image in the review pane to get a 100% crop view to test sharpness. For some reason a few weeks back this changed to 800% and try as I might I can't find out how to set it back? EDIT ok, now I've solved this one too... simply use the "+" and "-" keys to zoom in and out... not sure how I accidentally mis-set it, but there you have it...problems solved :-)
thanks for any help in advance
rob - check my galleries at http://hardlightimages​.zenfolio.com/ (external link)
Zenfolio coupon discount when signing up - 93R-NCK-DUT
Canon 5D Mkiii; Sony RX100; Lumix G5; 17-40L; 24L TS-E F3.5 Mk2; 24-105L IS; 40 F2.8; 135L; 70-200L F2.8 IS MkII; Ext II 1.4x; 580 exII; 270 ex... other filtery stuff:)
340 views & 0 likes for this thread.
2571 guests, 152 members online
