Will the 300mm F4L accepted stacked teleconverters?
Either a Canon 2x plus 1.4x Kenko or
a Canon 1.4x plus Kenko 1.4x
thanks
Dec 12, 2010 17:44 | #1 Will the 300mm F4L accepted stacked teleconverters? Mainly ANALOG..... but I still have a few digitals hanging around
gonzogolf dumb remark memorialized More info | Dec 12, 2010 17:47 | #2 If I remember correctly you can stack the TC's but you have some issues to deal with. I think only one of them will report to the camera, so that means your camera thinks you are losing one stop of light to the TC for instance when are losing much more. I'm pretty certain you also lose autofocus as well.
Green_Tea POTN Poet 645 posts Joined Dec 2008 Location: Columbus, IN More info | Dec 12, 2010 17:53 | #3 The reason you can't put the canon on some lenses it that it protrudes into the lens. If you go... 6D|7D| Sigma 50mm 1.4 EX| Canon 100mm L IS macro| Canon 24-70 II L| Canon MP-E 65| 600 EX-RT| MT-24EX
phreeky Goldmember 3,515 posts Likes: 15 Joined Oct 2007 Location: Australia More info | Dec 12, 2010 19:07 | #4 Physically the Canons are the pain due to the protruding elements like mentioned. If going on a lens that can take them, put the Canon TC onto the lens first, and behind that put the Kenko TC as they fit basically anything.
RPCrowe Cream of the Crop More info | Romy Ocon's great Philippine Birds site has had a few references to stacking converters. Although, not necessarily using the 300mm f/4L IS lens... See my images at http://rpcrowe.smugmug.com/
magwai Goldmember 1,094 posts Likes: 17 Joined Mar 2010 Location: Guildford, UK More info | Dec 14, 2010 05:43 | #6 i have stacked my canon 1.4x and canon 2x with the lens. it does get soft. it is better with just the 2x and crop the result.
richardfox Goldmember 1,883 posts Joined Oct 2009 Location: Bellbrook, Ohio, USA More info | Dec 14, 2010 06:26 | #7 I've stacked my 300 2.8 with both the 2X (mounted first) and the 1.4X. The lens info is transmitted incorrectly, but magnification is amazing. I did some live view manual focus shots of the moon earlier this year with both my 300 2.8 and my 100-400 (at 400). Being on a crop, I had good reach. Resolution stinks on this due to the re-size to post, but the original is quite sharp. This one was with the 300 with both TC's, and I expect you would get similar results with your 300 f/4. Canon 50D gripped, EF 50/1.8, EF-S 10-22, 17-40L, 24-105L, 70-200 f/2.8L, 100/2.8 macro, 100-400L, 300 2.8L, Canon 500 f8 mirror with chipped EF mount, 580EX, 1.4x and 2x Canon teleconverters, Canon EF Life-Size converter.
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Dec 14, 2010 07:16 | #8 Both Sigma and Canon TCs have protruding elements so they only fit certain lenses and cannot be stacked. Tamron SP, Kenko Pro can be stacked. I did once take some Eagle pix with a 2x and 1.4x on the 300/4 L IS lens. Not too bad really. But not really a good idea. GEAR LIST
Mk1Racer Goldmember 1,735 posts Likes: 9 Joined Mar 2009 Location: Flagtown, NJ More info | Dec 14, 2010 07:48 | #9 richardfox wrote in post #11449457 I've stacked my 300 2.8 with both the 2X (mounted first) and the 1.4X. The lens info is transmitted incorrectly, but magnification is amazing. I did some live view manual focus shots of the moon earlier this year with both my 300 2.8 and my 100-400 (at 400). Being on a crop, I had good reach. Resolution stinks on this due to the re-size to post, but the original is quite sharp. This one was with the 300 with both TC's, and I expect you would get similar results with your 300 f/4. I don't have a Canon 1.4x TC, but my understanding is that it's the same design as the Canon 2x TC (protruding elements). I don't think it's possible to stack two Canon TCs. 7D, BG-E7, BGE2x2 (both FS), 17-55 f/2.8 IS, 17-85 f/4-5.6 IS (FS), 50 f/1.8, 85 f/1.8, 70-200 f/2.8L IS Mk I, 70-300 f/4-5.6L, 550EX, Kenko Pro300 1.4xTC
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Dec 14, 2010 08:22 | #10 The camerea will only see at most one TC. Using 2 1.4x's might give you AF where using a 2x will not. GEAR LIST
LesterWareham Moderator More info | Dec 14, 2010 12:32 | #11 lmans wrote in post #11440386 Will the 300mm F4L accepted stacked teleconverters? Either a Canon 2x plus 1.4x Kenko or a Canon 1.4x plus Kenko 1.4x thanks I used to stack the Kenko pro 1.4X and Canon 1.4X II with this lens to retain AF on my 20D. This worked OK at least in good light. Gear List
artyman Sleepless in Hampshire More info | Dec 14, 2010 16:48 | #12 This was shot with Sigma 1.4 and 2X TC's on my 150-500 so that's 2240mm in old 35mm money
Art that takes you there. http://www.artyman.co.uk
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Dec 14, 2010 16:59 | #13 Yes, you can stack the Canon 1.4X and 2X... You just need to put a 10mm or 12mm extension tube in between them. Alan Myers
LesterWareham Moderator More info | Dec 15, 2010 00:20 | #14 Just a quick correction Alan, you don't need a tube to stack the Canon 1.4xII and 2xII as long as the 2x is next to the lens. Gear List
| Latest registered member is semonsters 909 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
