Thread started 14 Dec 2010 (Tuesday) 12:51
Editing a Bad Photo - C and C!
smackitsakic
Dec 14, 2010 12:51 |  #1
This is a photo I snapped yesterday. Please provide your comments and criticisms on my photoshop adjustments from the original RAW file (bottom images) to the corrected top image. What edits did I do right? What would you have done differently?
I essentially reduced the noise, adjusted the white balance, and gave it some contrast/saturation.
IMAGE: http://i1005.photobucket.com/albums/af173/smackitsakic/_MG_5514.jpg
IMAGE: http://i1005.photobucket.com/albums/af173/smackitsakic/_MG_5514a.jpg
Rachel ­ B
I normally pay attention
Dec 14, 2010 12:56 |  #2
You dont need to post the same image in two subforums...
White balance on the sewing machine is good, but the adjustment has made her skin very unnatural, create a new layer and make adjustments just for the skin then use a layer mask to paint (erase) all the everything but the skin away. Also needs a sharpen or faster shutterspeed next time.
40d, 30d, Canon 17-40L, 70-200 2.8 ISL, 60mm 2.8, Sigma 30mm 1.4, 18-55 Kit, 430exII 2xYN-460 II Flashes
stsva
Gallery: 45 photos
Dec 14, 2010 13:21 |  #3
I actually think the sewing machine looked better in the original as far as white balance goes, but her face had a strong orange tint from the incandescent light, which needed correction. Her face looks a little too blue in the corrected version, as does the sewing machine and rest of the image. I'd suggest importing into PS without the WB correct, then adjusting the color balance just for her face, either by selecting it then adjusting using a hue/saturation layer and decreasing saturation of reds and yellows or using a color balance layer, or by doing a global adjustment with either then painting on the layer mask for the adjustment layer so that it just shows on her face. The corrected image might also benefit from a little more contrast.
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
ChasP505
"brain damaged old guy"
Dec 14, 2010 14:56 as a reply to  @ stsva's post |  #4
I liked the original better.
Chas P
smackitsakic
Dec 14, 2010 17:14 |  #5
Thanks for the comments. This was a quick, off the cuff image that I snapped while she was taking a brief break from sewing so didn't have enough time to consider everything that is suggested. Thanks for the suggestions!
I may try to play around with this again using some masking techniques...i think it has more potential than what i've done with it to this point.
gotaudi
Dec 15, 2010 11:43 |  #6
Just desaturated the blue in the photo, it will make the sewing machine appear less blue.
Addicted2EOS
Dec 15, 2010 12:08 |  #7
Turn on "Image Editing OK" and some contributors will take a shot at editing the photo and show you how they might do it.
Canon 40D and more lenses than my wife knows about...
rw2
Dec 15, 2010 12:35 |  #8
ChasP505 wrote in post #11452175 (external link)
+1..
If you're afraid of failure ... you'll never succeed!
Rob
918 views & 0 likes for this thread, 7 members have posted to it.
2825 guests, 138 members online
