Thread started 14 Dec 2010 (Tuesday) 15:32
7D and the 430 EXII??
Neilyb
Gallery: 23 photos
Dec 14, 2010 15:32 |  #1
I would like to connect my 7D to control my 430 EX settings but all I get is the message that it is the wrong type of flash or it is not switched on. It is on, in ETTL mode, slave and pointing at the 7D.
I realize the internal flash does the triggering but to be able to set the strength of the flash from in the hide would be a bonus. :cry:
Any help would be appreciated as I have tried everything I can, even reading the manual :rolleyes:
http://natureimmortal.​blogspot.com (external link)
http://www.natureimmor​tal.com (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Dec 14, 2010 15:37 |  #2
Did you make sure they are both on the same channel, or rather that the channel the 430 is on is being recognized?
scroller52
Dec 14, 2010 15:39 |  #3
if it is on ettl...the camera will choose the flash power...??
u can use flash exposure compensation though. if you hit the iso button and move the backwheel, it will change the FEC.
Canon EOS 5D3 | Canon 24mm 1.4L mkII | Canon 85mm 1.2L mkI | Canon 40mm 2.8
my flickr (external link)
my picasa (external link)
apersson850
Obviously it's a good thing
Gallery: 35 photos
Dec 14, 2010 15:47 as a reply to  @ scroller52's post |  #4
What you haven't realized is that when you are controlling flashes through the internal master in the 7D, then all settings are done with the internal flash. This includes those that concern the external slaves.
Settings for the external flash is only valid for an external flash in the camera's hotshoe.
Set your internal flash to remote control, select if you want to use both the internal and the external, or the external only, and then apply the settings you desire to the external flash through the internal one.
If you still don't get it, come back.
Anders
JayJphoto
Dec 14, 2010 17:14 |  #5
Is the 430EX II set to slave on the flash unit?
5D, XTi, 17-40mm f/4L, 70-210mm f/4, 50mm f/1.2L, 85mm f/1.8, 3 - 580EX II, Alien Bees, smoke, mirrors, etc...
http://jayauskalnis.co​m (external link)
Neilyb
Gallery: 23 photos
Dec 15, 2010 03:29 |  #6
http://www.youtube.com​/watch?v=iKYDFHYZg3o (external link)
In this video he describes how you can manually control a flash, or any flash, within a certain group...that to me says I can do it remotely and not attached to the camera.
Flash is set to slave, groups and channel are correct. Will not connect. Flash and camera are close and facing. Damn, I am wondering if my 7D is faulty :(
FlyingPhotog
Cream of the "Prop"
Dec 15, 2010 03:31 |  #7
I freely admit this is a question based in ignorance since I don't have a 7D but...
- Does the built in flash have to be extended?
And...
- If so, is it extended?
Jay
Neilyb
Gallery: 23 photos
Dec 15, 2010 04:34 |  #8
Built in flash has to be extended to fire the remote units. Not to connect. But either way it is extended.
npompei
Dec 15, 2010 08:24 |  #9
Did you hold in the "mode" button (I think thats it - button on the far right of the flash unit?) It will turn into "wireless mode." That should allow you to connect with the camera and fire.
I am trying this off the top of my head without my camera in front of me. Mine did the same thing and I just forgot to put the flash into the correct mode. You can then go into the settings in the camera and adjust FCE.
www.nickpompei.com (external link)
Canon 5d3-gripped / Canon 5d / Canon EOS M / Phottix Mitros + (3) / Tamron 17-35 (2.8-4.0) / Tamron 28-75 (2.8) / Canon 35L / Canon 50 (1.4) / Sigma 85 (1.4) / Canon 70-200(2.8)IS
dedsen
Dec 15, 2010 08:26 |  #10
Just to reiterate what Anders stated above.
You CAN control the 430 remotely with the 7D, but it IS NOT going to be accessed via the EXTERNAL flash menu. You will control the 430 with the BUILT-IN flash menu. You select WIRELESS FUNC. from that menu and you will see that you can choose EXT:POPUP or EXTERNAL only or EXT+POPUP. After you chose one of these options you decide if you want the slaves in eTTL or manual and the appropriate control choices will appear.
If there is not a compatible flash in the hotshoe of the camera, the EXTERNAL menu will always display INCOMPATIBLE FLASH or NO POWER.
Hope this helps.
Neilyb
Gallery: 23 photos
Dec 15, 2010 09:07 |  #11
OK. The external flash menu is for the flash only in hot shoe, I see that now... but I still didn't manage to remotely access the flash settings in the built in flash menu. A guy here at work knows and he will show me tomorrow. Thanks for the help guys.
Neilyb
Gallery: 23 photos
Dec 15, 2010 16:07 |  #12
OK, got it. You have to set the built in flash menu to Manual to get the manual control of the groups...Darn, why did I miss that one :| OK, its all good. So, will probably need my remote triggers anyway if I need the in built flash, from within a hide, to trigger.... :|
apersson850
Gallery: 35 photos
Dec 16, 2010 04:25 as a reply to  @ Neilyb's post |  #13
Yes, unlike Nikon's CLS, Canon's remote flash system always uses all flashes in the same mode. You either use E-TTL for all of them, or manual for all of them. Master included.
Well, you can use E-TTL and set a slave to manual independently, but then you can't control it from the master any longer.
Anders
canongrip
Joined Jun 2010
Dec 25, 2010 06:24 |  #14
dedsen wrote in post #11455974 (external link)
Hope this helps.
I have one question.
I want to go wireless with 7D and 430EX II.
There are 3 options:
  • POPUP
  • EXTERNAL only
  • EXT+POPUP
But if I choose the option "EXTERNAL only", the built in flash also fires.
Why?
In eiher cases, "EXTERNAL only" or "EXT+POPUP", both flashes (430 and built in) fire..
What am I missing here?
gear list & historic
Madweasel
Dec 25, 2010 07:11 |  #15
The built-in flash communicates with the slave unit(s) by firing. It won't fire for the exposure if you've selected "external only".
Mark.
4,505 views & 0 likes for this thread, 12 members have posted to it.
1459 guests, 136 members online
