Thread started 14 Dec 2010 (Tuesday) 16:17
Which kit lens?
FredM
Joined Nov 2005
Dec 14, 2010 16:17 |  #1
Hello
I am about to buy a DSLR and have a choice in kit lens.
Either the EF-S 18-135mm 1:3.5-5.6 IS or the EF-S 18-55mm f/3.5-5.6 IS Lens will come with the camera. The 135mm is slightly more.
Does the additional adjustment in the 135mm give up some quality?
thanks
xarqi
Dec 14, 2010 16:36 |  #2
Welcome aboard.
I'd recommend the 18-55 IS over the 18-135.
Few have anything negative to say about the former, or positive about the latter.
If you think you may want a longer focal length, look for a kit that also includes the EF-S 55-250 IS.
themadman
Dec 14, 2010 16:42 |  #3
xarqi wrote in post #11452665 (external link)
Welcome aboard.
+1 I'd say about the same thing.
Welcome to the forum!
EDIT: Wow, you joined in 2005 and this is your first post?! Intense!
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
xarqi
Dec 14, 2010 16:50 |  #4
themadman wrote in post #11452699 (external link)
That's some fine lurking right there!
FredM
Joined Nov 2005
Dec 14, 2010 17:13 |  #5
i wish I would have learned something in that time. I wanted an SLR back in 2005 but ended up getting a point and shoot which is what the DSLR I am buying now will replace.
If it helps, I plan to first use this camera for single person portraits outdoors with minimal to some background. Which lens would be best for that right off the bat?
Something like this.
I know there are depth of field and other considerations with this type of pic so don't get bogged down into the details of that exact shot but that is what I plan to do with the new camera right off the bat as far as distance and amount of background.
xarqi
Dec 14, 2010 17:18 |  #6
For this type of work you are best off with as long and fast a lens as you can afford, and probably a zoom (for ease of framing).
In rough order of increasing cost and suitability:
55-250 IS
70-200/4 (IS)
70-200/2.8 (IS)
... or look at a prime like a 135L, 200 or 300.
Dream lens for such work 200/2L (IMHO).
FredM
Joined Nov 2005
Dec 14, 2010 17:22 |  #7
xarqi wrote in post #11452889 (external link)
55-250 IS
70-200/4 (IS)
70-200/2.8 (IS)
So between the two kit lens I should get the 135mm correct?
watt100
Dec 14, 2010 17:25 |  #8
FredM wrote in post #11452862 (external link)
get the 18-55IS with the camera, it's an inexpensive sharp "walk around" lens and the 50mm 1.8 ($100) - great for portraits
watt100
Dec 14, 2010 17:25 |  #9
FredM wrote in post #11452915 (external link)
no! - don't get the 18-135 !
BestVisuals
Dec 14, 2010 17:34 as a reply to  @ watt100's post |  #10
I'd say "quit saying kit lens". Your lens is the primary determination of quality. If you have any plans to sell your images, don't get a kit lens at all. Get the best glass you can afford.
Canon 5D MK II, 24-105 L, Sigma 16mm fisheye
xarqi
Dec 14, 2010 17:40 |  #11
No.
You've asked what I thought were two questions, but maybe it's only one.
If you are deciding between the 18-55 IS and the 18-135, get the 18-55 IS on image quality grounds. It's "good", the 18-135 is "bad".
If you want the best lens for the type of work you want to do from day one, get one of the lenses from the list I gave (possibly in addition to the 18-55 IS, which would be used in "walk-around" situations).
With the 18-55 IS alone however, you should be able to achieve results similar to the example you have shown with careful selection of shooting location (distant background, etc).
xarqi
Dec 14, 2010 17:44 |  #12
I'd also endorse watt100's suggestion of a 50/1.8 as a way of extending the abilities of the 18-55 IS as far as your portraiture is concerned. It's fast enough to give you some decent background blur, long enough to enable you to work from a distance where the perspective will be flattering, and it's inexpensive. The downside is that it is a bit fragile and many dislike its bokeh.
(P.S. - other downsides to the 50/1.8 - slow AF, noisy, and poor AF in low light)
Player9
Dec 14, 2010 17:47 |  #13
I would go with the 18-55mm IS over the 18-135mm IS. The 18-135mm has more distortion at the wide end and it doesn't have the awesome close focusing capability of the 18-55mm. YMMV.
RP, 60D, RF 24-105mm f/4-7.1 IS, RF 35mm f/1.8 IS, RF 50mm f/1.8, EF-S 10-22mm f/3.5-4.5, EF-S 18-135mm 3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS, Tamron 17-50mm f/2.8, EF 28mm f/1.8, EF 50mm f/1.8, EF-S 60mm f/2.8 macro, EF 85mm f/1.8, El-100, 430ex, 220ex, Alien Bee B400 (2), Alien Bee B800 (2)
FredM
Joined Nov 2005
Dec 14, 2010 18:01 |  #14
xarqi wrote in post #11453012 (external link)
No.
Thanks for clearing that up. I was thinking to get the 50mm as so many people recommended it and it is inexpensive.
FredM
Joined Nov 2005
Dec 14, 2010 18:15 |  #15
OK I am pretty excited now. Just ordered the package with the 18-55 and added the Normal EF 50mm f/1.8 II lens. First test will be Christmas portraits and snapshots.
3,599 views & 0 likes for this thread, 10 members have posted to it.
Which kit lens?
1400 guests, 109 members online
