Thread started 14 Dec 2010 (Tuesday) 18:16
Mini review PhotoClam PT-124 Pro Carbon 8X Tripod
ddong
Dec 14, 2010 18:16 |  #1
Just got it 20 mins ago. I am probably the first person having this tripod after I posted a thread two weeks ago (maybe longer). I really don't have time to do full review recently, so mini review instead, sorry guys.
old thread is here, in case you wonder what the tripod spec is: https://photography-on-the.net …ighlight=photoc​lam+tripod
I finally decided to go with PT-124 instead of PT-125 because it supports more weight (13kg) and more stable than 5 sections tripod.
First impression, WOW!! this tripod is definitely worth every penny! even it's not cheap! (based on my experience with Feisol, Manfrottoand and Gitzo traveler tripods). The building quality is amazing! I'll say at least good as Gizto if not better. The reason I didn't go with Gizto 1541T because I am 6"4 and never used center column. Gitzo is too short, but I like Gitzo's build quality. Since then I did research for every available traveler tripods on the markets to match Gitzo's quality and taller, none of them are good till recently I found PhotoClam PT series.
Sorry guys, I have to go to company's christmas party 20 mins later, this review has to be short. Let's see some pics below, when I have time, I'll do detailed review about this tripod.
1. what's in the tripod package
2. close look
3. leg, spike and cap, again, build quality is really high(Gitzo 1541T should provide this option too)
4. comparing to my Gitzo GT2542L. It should be tall enough without center column extended. this is really good for tall people.
5. center column (I never used center column for any tripods, first thing is taking it out)
6. how it looks from bottom after I replaced with macro plate
7. works great with my Markins Q3T ballhead
8. this is way better inside build than Feisol 3441s. it only has one piece but Feisol has 3 pieces on the leg locking part. most of Chinese Gitzo copies do the same.
Quick Conclusion
1. This tripod's build quality is really really high (again based on my experience with few traveler tripods), when you actually see it, you'll know what I mean, just like Gitzo, hope this will give you some sense what it is. Hopefully leg screws don't need to be tight so often, like Feisol 3441s
2. Feisol traveler tripod is pretty much the same price as PhotoClam, but quality doesn't match, so if you're considering Feisol, definitely considering PhotoClam as well
3. So far, what I do not like is, when you replace with macro plate, you can't mount the center column hook on bottom, Gitzo 1541T can
ddong
Dec 14, 2010 18:17 |  #2
last pic, beautiful carbon fiber finish on legs, you can tell which is PhotoClam and which is Gitzo
static808
Dec 14, 2010 18:56 as a reply to  @ ddong's post |  #3
great initial review. cant wait for the in-depth stuff...
Rob
ddong
Dec 16, 2010 22:55 |  #4
few more pics
it's snowing, did't have chance to go out yet
works great with Markins Q3T
mayuka
Dec 17, 2010 13:17 as a reply to  @ ddong's post |  #5
Wow. Just another china copy of Gitzo...
ddong
Dec 17, 2010 13:33 |  #6
mayuka wrote in post #11469829 (external link)
Don't be surprised. Everybody is copying Gitzo but this copy is better than Chinese copies. Quality is almost equal to Gitzo. Time will tell how long it'll last.
tvphotog
Dec 17, 2010 16:16 |  #7
ddong wrote in post #11469911 (external link)
Without looking at the metallurgy and the CF manufacture methods, you can't say that. Do you have that information from the Korean makers and to compare to Gitzo's methods?
That said, I like the spring loaded hook.
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
ddong
Dec 17, 2010 16:43 |  #8
tvphotog wrote in post #11470854 (external link)
I emailed them already, waiting for reply. I took it apart and compared with my Gitzo 2542L, their CF is thin. I guess 8X is thiner than 6X? Anyway, this is what they claimed. I did have hands on Gitzo 1541T for a month, IMHO, quality is identical to Gitzo, of course, manufacturer process is the key.
This one is definitely better than Feisol 3441s (I had this one for almost 2 years) in terms of handing and build quality.
mayuka
Dec 18, 2010 03:52 |  #9
ddong wrote in post #11470983 (external link)
No. 8x just means that they're using 8 layers of carbon.
Gitzo "only" uses 6 layers, but each layer has a very high amount of carbon fibres. In addition to that each carbon fibre is folded with other fibres like a pigtail. To my knowledge the other manufacturers don't use these production process because it's very time consuming and expensive.
There are differences in the manufacturing process of the metal parts too. Gitzo is not pressing the metal parts into the pre-defined dies, they mold it into them which requires to heat up and fluidify the metal. This results in very robust parts that bear higher loads.
The Photoclam reminds me of Feisol. Maybe it's the design and they copied them. :cool:
Levon ­ Jensen
1 post
Dec 23, 2010 18:21 |  #10
The Website states it is 52 inches tall. without center. that seems short, do you have to bend over alot?
Do you mind posting a picture of it at max height with a camera and your self?
im 6'3 and As i was looking at http://reallyrightstuf​f.com …/TripodCollage/​index.html (external link)
it seems id need a 58inch or so tripod.
Am i better off with a pt 324?
Thanks! and Great review
ddong
Dec 24, 2010 12:11 |  #11
Levon Jensen wrote in post #11505124 (external link)
If you look at pic #4 (comparing to my Gitzo 2542L), Gitzo is my eye level setup. That may give you an idea how much bend over you need. For me, yes, I'll have to bend over but not that much.
For RRS tripod, I really don't have any experience with it, so I can't say anything.
saab
Mar 18, 2011 09:30 |  #12
Sorry to bring this thread back up, but I am wondering how this tripod is working for you. I am looking to pick it up as it looks perfect for my needs. Thanks.
"There are no rules for good photographs, there are only good photographs." ~Ansel Adams
ddong
Mar 18, 2011 22:41 |  #13
I used it for few month now, it's really good for travel and hiking (this is why I bought it for). If you don't have really heavy stuff load on it, daily use is pretty good too. I don't have any problems to load my 5DII and Zeiss 21mm on it.
So, overall I am really happy with it. Report back when you have it.
Good luck.
rchr
Apr 04, 2011 10:16 |  #14
Hey Ddong,
I've been looking for a good tripod setup at the moment, was considering the Feisol 3441T before. May I know how much you got this tripod for?
midget
Apr 04, 2011 12:08 |  #15
rchr wrote in post #12154587 (external link)
Hey Ddong,
its on ebay right now for $365.
40d + 50mm f1.8 MK I + my feet.
11,390 views & 0 likes for this thread, 10 members have posted to it.
1320 guests, 120 members online
